Parking rod problems
Started by chargd72, October 04, 2014, 01:17:47 AM
chargd72
I recently pulled the VB out to replace the shifter seal in my 904. Got it all back together and I can't get the transmission into park. All other gears work the same as before but now it gets stuck between reverse in park. Did I mess something up with the park rod? Didn't change anything.
don duick
disconnect the shifter rod and put the lever into park and with the shifter in the park position check if it lines up. If not you will have to re adjust it. repeat this process with the lever and shifter in 1st gear.
chargd72
It's something sticking inside the transmission. Lever won't go in park with the shifter disconnected either. That's why I think the parking rod is the culprit.
The park rod might be installed below the pawl (see pic below) instead of to the right where it belongs.
One way to prevent this is to clock the snap ring all the way clockwise so the lower ear on the snap ring covers the gap and guides the end of the rod into the proper position.
chargd72
Well sh!t. I just sealed the thing up. Everything I read just said to make sure it went in the correct hole. Didn't know it could seat incorrectly.
ACUDANUT
Quote from: John_Kunkel on October 04, 2014, 12:02:46 PM
Good info !
ws23rt
 :2thumbs: Another great tid bit and good photo to give clarity.
don duick
sorry I did not realise what the park rod was now I understand.
chargd72
Thanks for the pic, John.  Looking at the picture again, if the rod seated bellow the pawl I think the shifter would still be able to make into the park position.  It's more like something is obstructing the rod stopping the lever right after the reverse position.  Either way, I'm probably screwed and have to take it apart, ... again.
The "knob" at the rear of the park rod is spring-loaded to allow shifting to Park regardless of the pawl position but that only works if the rod is in the correct position against the rear of the tapered ramp.
chargd72
Does anyone know if this would render the transmission useless?  Since I had the pan sealed up I thought I'd at least see if I fixed the shift lever leak.  I started it up and ran thru the gears and none of them engaged.  I posted this question the the General section but didn't get any bites.  Any help is much appreciated.
chargd72
John, you nailed it.  Pulled the VB back off this weekend the the rod was stuck behind the pawl just like in your pic.  Should be good to go now.
