my new carb
Started by Stegs, September 08, 2014, 10:41:31 AM
Stegs
well guys, I was having trouble with my factory carter.....I had a bad surge going 45 or faster.....plus I had a really bad stumble when starting out from a stop sign.
Car would spit and backfire, and then it would take off like crazy
Anyway, got the carb off and had a 'expert" look at it.
Turns out my accelerator pump was  shot and there were some rods ? for the float that were bent horrible.....
Long story short he pretty much said I need a entire rebuild, but by that time id be better off with a new carb
I told him I was thinking about a holley or a proform......he told me he has never been let down by a edelbrock carb
Well he made me a deal on a new edelbrock and put it on.....and I must say WOW!
really showed me how tired and worn out that carter was. He suggest that I go with a 600 cfm and wait to go bigger until I add bigger cam/heads etc
I must say the 600cfm I thought would be too small, but when the vac secondary's open....wooooo she moves!
im glad I went this way, the car runs and idles way better, no more surge or sputter !
I know you guys said go with holley or proform, but so far I love this edelbrock! I hope it continues to preform this good years down the road
ODZKing
What was the Carter?
What engine?
What year/car?
The Edelbrocks are essentially knock offs of the Carters so it should be fine for quite a while.  Its kind of a plug and play carb in a sense.  Did you get the Performer or the Thunder?
Stegs
the carter was the original that came on a 440
car is a 69, motor i think is a 70, might be a 69
and yes the edelbrocks was a direct bolt on, we only needed a adaptor for the linkage
i went with the performer series, 600 cfm vac secondarys
Thats like an AFB then, it'll work well.
Stegs
Quote from: Ghoste on September 08, 2014, 11:51:18 AM
so far its a night and day difference....I figure if it can get me by for a few years while I save up to build the 440 a little, that's good with me.
car runs great on it, matched with my firecore ignition.....really woke it up
Oh yeah, it'll be more than a few years.  Not a lot to go wrong in one.
Stegs
Quote from: Ghoste on September 08, 2014, 12:00:05 PM
good to know...I know a lot of people said not to get a holley, and that I would be disappointed. But This guy promised I would like and I must say, its pretty nice....easy to adjust (if I needed too)
im happy this far
The Holley is awesome and can outperform the Carters but in a case like yours I don't think you're as concerned about getting it tuned to that razor edge right now.
Stegs
Quote from: Ghoste on September 08, 2014, 03:28:03 PM
not at all, ill save that for later on when I go thru the motor....but right now to get the car back up to a great running and driving car, this will work and does work awesome
Good to hear the car is running better.  :2thumbs: For some reason the eddy 600 carbs are better calibrated than the larger 750 version. I've heard this from a few guys who use them in a race dual quad setup using a crossram.
That carb should give you wicked throttle response due to the smaller venturies and increased velocity  :drive:
Stegs
Quote from: firefighter3931 on September 09, 2014, 09:43:52 AM
its got good throttle response for sure, way better than what I had of course....one thing I really like is the car is very "drive-able" right now....but its like a world of difference once those secondary's kick in.......car moves.....I think I did notice when I got home that I had some knock going on at higher rpms....
now he tuned the carb hooking it up to the vac machine...so that might be off or I need a timing change with the new carb...otherwise from idle to 3/4 car runs great!!
The high rpm "ping" could be a fuel issue....it might need increased jetting on the secondary side. If the carb was just bolted on out of the box this is likely the case because a single 600 cfm carb is on the small side for even a stock 440.  ;)
And is not the issue with the 750's that they are set up lean?
Stegs
Quote from: firefighter3931 on September 09, 2014, 07:39:18 PM
ill have to drive it some more this weekend when it finally stops raining (I hope) I will put some miles on it and see what it does...make sure that's its the carb and not some other noise....
we will see this weekend
and I thought a 600 cfm carb was the correct size for a stock 440, then when you modify you would go bigger? I thought for sure I read that somewhere here on the forums???
anyway, either way the car runs great the way it sits, just got to make sure the pinging, if I have to change the jetting, that's no big deal...
myk
Question:  why is it that online 'carb CFM "calculators" typically recommend much smaller numbers than what is generally accepted by people who know and build these sorts of engines and setups?
Stegs
Quote from: myk on September 10, 2014, 09:56:54 AM
well according to summit racing carb calculator a 440 with a maximum rpm of 5000 needs a carb to flow 541 cfm
I have a 440, get no where near 5000 rpms with it and have a 600cfm carb
The calculators are generic by nature so don't necessarily apply to all engines.  Plus, with car guys if more is better than too much has to be perfect which leads to things like Dominators on your 318 and then with the resulting performance loss from that the carb builder becomes the bad guy.  Easier to recommend small which will give  sharper throttle response and overall more driveability in many situations.  And there are a lot of ways to grade carbs.  So a Holley rated at 750 could be larger than a competitor rating of 800 based on how they were tested.  This can make for a lot of confusion.  In general,  its best to be conservative.
If an engine already benefited from good heads and cam design and such, like many Mopars, then often a bigger carb will bring some more to the table.
fy469rtse
i agree with ghoste, too many varibles,
easy way for you stegs is get the tuning kit for your size carb, comes with needles, jets and a chart for jetting up , remember dont do too many things at once , change try it , if its wrong easy to change back or know what you did wrong
Challenger340
To Carter Carb sizes....
My '69 Charger R/T factory 440 Magnum Engine, has a Carter AVS Carburetor, which is stamped #4618S. It is Factory original never touched same as the Engine,  until I had to change 1 float that went heavy, but that's another story.
Anyways,
Depending upon who you talk to ? or what spec book and guy refers to ?... the 4618S carter carbs were between 750 to 800 cfm ?
I never liked Carters... I've pitched more of them in the can over the years than I care to relate... until THIS factory one I have here !
It performs flawlessly with good idle, great response, and very good power.
Only wimps wear Bowties !
Stegs
well ill get my carb jets properly done and then go from there
I hope to get out and drive it but its been raining here for days its seems  :brickwall:
don duick
I also have a 600 edelbrock performer carb and it runs great but I do get more performance from my 750 holley. I use this edelbrock carb as a backup when and if my holley plays up, which it has for unknown and mysterious reasons. your edelbrock carb does not have vacumn secondaries they are mechanical. You must be referring to the plate above which opens with the secondaries. If it runs as good as you say I would not touch it. If you do, keep reference of the jets and rods that are in it now.
I agree, don't fix it if it isn't broke.
69wannabe
I prefer a holley over an edelbrock but I have had better luck with the 600 eddy's over the 600 holley's. On the other hand the holley 750's are a much better carb than the 750 edelbrock IMO. Since I have had the charger with a big block in it the 750 holley DP was the best carb I ever had. I have an old 625 AVS that is a pretty good carb I use as a trial carb, the larger version AVS's are kinda hard to come by seems like since they were used on all the HP 440 engines and most people that have good one's tend to hang on to them. I have tried only one of the thunder series AVS carbs on a 304 jeep engine and it worked very nicely on there. Haven't heard very muck about these carbs but the one I got for the jeep was a good one. Anybody on here tried one of them summit 600 carbs??? Wonder if they are any good for the price???
Stegs
Quote from: don duick on September 12, 2014, 05:01:24 AM
I thought they were vac secondary......but I was mistaken .......but one thing I know is when they open up its quite the ride!..
and when I put the car in 1st gear and mash the gas, it will spin the tires thru 2nd gear into 3rd......never did that before either
