rear framerail bolt
Started by Brian in GA, July 31, 2014, 10:25:41 AM
Brian in GA
Okay, guys, I'm in the process of replacing my rear crossmember on the 68. The nut and bolt that attach the bottom end of each side of the crossmember to the frame rail was rusted up and I had to cut/drill them out.  Does anybody make a reproduction, or what size nut/bolt/washer should I use?
As always, thanks for the help.
