Dixie Horn Install
Started by Matthan, July 28, 2014, 01:51:05 PM
Matthan
I have a 69 Charger. I have purchased a Dixie Horn to install and wanted to use my stock horn button. Does anybody have any pics and instuctions on how to do this?
mopar0166
Both of mine work fine.  I use the washer button for Dixie
Matthan
How did u install it (wire)....any pics?
Matthan
Ireally wanted to wire it though my exsisting horn
mopar0166
You will want it seperate from the stock horn.  i used the washer button , mounted my relay the facinty of the stock horn and the dixie horn gets mounted on the rad support.  it makes it easy to wire.
basically you are using the washer wire as your tigger wire for the horn.  you will also need a constant 12v source as well but having some wire laid already helps
why not to use a selector switch under the dash to be able to use the original horn button? Just an Idea
double on, two positions, single pole.
Or maybe a push big push button located at a side of the floor headligths dimmer switch
Bob T
I put one into a friends Coronet, the compressor draws 20 Amps, so either way you will need upgraded wiring a.d relays for it. You can use your existing horn relay in the engine bay as the trigger for the new upgraded relay with the appropriate wiring and fuse installed.
Old Dog, Old Tricks.
mopar0166
i used 8 ga wire for my 12v source for the relay and use the washer button as a tigger, also hides the button from unwanted use.  the horn kit comes with the relay you just need better wiring depending on how long the run of wire is
actually the stock relay can handle the load for the air kind horns
mopar0166
I have found that to get he right speed and pitch you have to upgrade the source and thiers also a few other tricks
