tinkering with my six pack '70.. Brake line resto...
Started by hemi68charger, March 16, 2006, 10:33:12 PM
hemi68charger
Man, I'm outside messing with the 2 '70's I have and it's great therapy....
I installed the Bendix Booster I have onto the '70 and replaced a bad upper door belt moulding with a good one.. It's sometimes the little things that are the most fun..
Has anyone bought, either through FineLines or InLine Tubing, the master cylinder lines from the master cylinder to the proportioning valve?
Houston Mopar Club Connection
Shakey
Quote from: hemi68charger on March 16, 2006, 10:33:12 PM
Hey Troy,
I am in my hotel room in Detroit, MI as I type this and I will be picking them up shortly.  I actually ordered the 8 piece kit (complete) from Inline Tube as my '69 is a disc brake car.  Since my car has had a number of incorrect surprises I have found since I started to dismantle it I am going by what I have seen on some other cars, most notably the '69 I found in a salvage yard that had a master cylinder (correct Bendix casting # with ports on the engine side), saftey tee / switch and proportioning valve still attached.  See the photo below.
I will take some pics when I get a chance.
hemi68charger
Quote from: Shakey on March 17, 2006, 07:03:31 AM
Hey Troy,
The '69s are going to be different than '70's I believe..  69s don't have the dual setup........
dodgecharger-fan
hemi68, when you say "dual" are you referring to the tee and prop valve?
That picture is exactly what I found on my 69. (The rust looks exactly the same, too....  :icon_smile_shy: )
That picture is also the same as the setup on my 67.
hemi68charger
bad88t-top
Does any of the 70 guys out there know where the black plastic clip on shield goes on the brake line?  Somewhere near the proportioning valve.  Thanks in advance. :shruggy:
TX9 70 Charger RT: 6 pack, 4 speed, A33 Saddle interior, red stripe
EB7 70 Charger RT SE: PS, PB, PW, PSunroof, Defogger, Air, loaded
FC7 70 Charger RT: 440 4 speed, Dana, white longitudinal, black vinyl
EB5 70 Charger RT: 440 4 speed, Dana, B5 interior, white long stripe
EB5 70 Charger RT SE: V code 4speed A34, charcoal interior, loaded
F8 69 Charger: Power Sunroof Car
13 Duramax 2500HD: Tow Rig
17 Durango RT
oldcarnut
This was from my 70RR if this is what your refering too.
oldcarnut
Here's a link to my front end build.  Its on page three near the bottom if the link doesn't take you there.  Unfortunately I didn't know better when I turned my Bendex core in when I got this one that they were hard to come by.  I bought all the front lines (SS) and new valves.  I'm having a hard time getting one of them to seal on the p-valve
http://www.dodgecharger.com/forum/index.php/topic,53678.50.html
Went ahead and shot a couple different views.  Yep it's still in this stage of putting it back togethor as it was when the other pics were taken   :icon_smile_sad:
I would order brake lines from Dave @ Roseville Chrysler in Mi you should get a discount , my experience with Inline has always been bad
