Bendix booster ?
Started by horse, June 20, 2014, 07:41:08 PM
horse
Can someone please help identify this Bendix booster as i cant find any numbers on it.
Bolt pattern is
4 1/8 stud down
3 1/4 stud across
5/16 studs
3 3/8 rod length from centre of rod hole to back of booster base. If not correct what length should rod be?
I am wanting to install on my 68 RT Charger and ditch the repop that has only lasted 400 miles
1968 Dodge Charger RT 440 4 speed Dana car
1970 Dodge Challenger RT 440 4 speed Dana car
hemi68charger
That is a Bendix Booster for power disc brake cars of the day. Now, not sure off the top of my head if it is a B or C body version. There may not be a difference.
I have my Bendix out of the Daytona, so I can make measurements to see if it matches yours unless someone chimes in. Off to church now, so it'll have to be later on...
Houston Mopar Club Connection
hemi68charger
Here's what I have, came off my Daytona when I replaced it with the Hemi Bendix Booster Assembly.
horse
Are you able to please measure the rod from the center of hole to base of back of booster....my one is 3 3/8
Thanks for your help Troy
hemi68charger
Quote from: horse on June 22, 2014, 03:25:03 PM
When I get home tonight I will......  :2thumbs:
hemi68charger
From the backing plate, to the end of the rod is about 3.5" ( not center of hole, but end of rod )....... I can tomorrow take the backing plate off and measure just like yours.
horse
Thanks Troy once ai have that final measurement I will send this for rebuild
hemi68charger
the rod seemed to measure 3.25" from base to centerline hole.....  :2thumbs:
horse
