71 Bumper install
Started by 4aThrill, June 01, 2014, 10:06:46 AM
4aThrill
been trying to adjust the bumper so it lines up with the fenders, passenger side fender is max out, driver still has some room but not much. just wondering how to align bumper to each fender. before restoration, bumper was stuck on the car as I remember I had to pull off with force, and it was aligned just fine with no gaps on the hood. I know things change after time but any thoughts?
4aThrill
thinking just get it even as possible wont be lined up withe fenders
ACUDANUT
Quote from: 4aThrill on June 01, 2014, 10:20:23 AM
Huh ?
4aThrill
we have moved it left and right up down, just the bumper and the fenders to last night, I was just thinking maybe just have some of the bumper over hang on both sides of the fenders. instead of one side align and the other side way the f out there.
71charger_fan
You may have to pop off the whole assembly and oval out the holes in the brackets for the bumper bolts a little to buy a little adjustment. There's not a lot of left-right wiggle room with that setup.
4aThrill
actually did that the other day, holes were only an inch now the driver side holes are one inch and 3/8's, just little movements left and right.
RallyeMike
For what it's worth, I have always had a difficult time aligning a 3rd gen front bumper. Loosen the bumper to bracket bolts too for a little more adjustment especially for side to side.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
4aThrill
moved the bumper around last night, will post some pics later, fitted the grill inserts in, just gotta put the valance on, adjust the ride height and fix the leak on the brake lines  :-\, good thing using DOT 5, everything is new lines booster, valve.
