Summit headers
Started by sext7366, March 14, 2006, 10:44:50 PM
71440charger
i just put them on my 71 and the fit with out cutting anything it is just tight and takes time you will need two people or atleast i did tomake it easier
The Killer Cam
palindromes
Just as a follow-up, I'm still working on installing the summit exhaust with the summit headers.  Headers fit great, but found the pipes needed some adjusting (cutting and welding) in a couple spots.  Looking at the instructions more closely, there's a disclaimer that the summit exhaust is designed for the hooker supercomps & anything else may need modifications.
Still, for the price, I've got no complaints...but make sure you've got access to a welder or tubing bender if you go with this combo!
BigBlockSam
Smoke20
UPS just came by and dropped off 2 big boxes.
Looks like I'll be gettin' busy this long weekend.
Kevin
It's MoPar or No Car!  :drive:
'69 Dodge Charger - Black primer
01 Dodge Intrepid R/T 3.5L Magnum V6 36K
05 Dodge Grand Caravan SXT Inferno Red, Loaded
