window lube
Started by r4daytona, May 12, 2014, 09:23:16 AM
r4daytona
Anybody know of what I could use to lube my window tracks?  They have the new strips/seals that slide in the track but what can I use to "grease" them?  I thought about graphite for the back one since it closes to the rear window and the stainless is visible when the window is up.  Thanks  Tom
Silver R/T
Are these seals rubber? If so you can use silicone lubricant.
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Scaregrabber
They make a special lubricant, it comes in stick form and you unwrap the paper around it as you use it up. A good parts supply house should have it.
Sheldon
GreenMachine
Quote from: Silver R/T on May 12, 2014, 10:20:54 PM
:iagree:
That's what I've used on a few cars and the windows roll up and down very easily. Silicone grease, not the spray.
Cooter
Graphite powder works well too.
rt green
third string oil changer
rt green
