tac not working
Started by 71chargerrtclone, May 06, 2014, 07:09:52 PM
71chargerrtclone
I have tried three tac's and none of them work. I'm even hooked them up in the engine bay, negative on the coil and the other connection to 12vdc. I have electronic ignition.  Thanks
what "type" of electronic ignition? What type of tachometer?
A little more info would be helpful here. Did you connect the ground wire as well?
71chargerrtclone
Okay it was a bad ground. That must be my problem with the dash lights not working too on my new wiring harness.
Oh yes, it all has to be grounded.  You weren't testing this stuff with the cluster out of the dash were you?
