Modern Bullitt build
Back N Black
You attention to detail is amazing!!!!  :2thumbs:
Rolling_Thunder
Gotta ask for the ignorance of me - I'm starting to work on my 73 Challenger project over on Andrews AFB and curious how your get the metal so clean and smooth? I assume an angle grinder with a sanding disc and then wipe down with paint thinner ?
Clean metal is way easier to work with ---   Also are you using a MIG for all these welds ?  If so it's down right impressive!
I may just have to drop my Challenger off to you with a check for rear sheet metal replacement!    :nana:
Truely impressive work my friend
keepat
Quote from: Back N Black on February 20, 2016, 07:21:24 PM
Thanks!
Quote from: Rolling_Thunder on February 21, 2016, 12:59:40 PM
Do you get to keep and work on your Challenger on base? if so that is cool! I'm only about 35 minutes from AFB, if you get a chance you should drive over and I'll show you a good friends 72 Challenger that he had to replace most of the metal. it was his 1st car but sold and found 25 years later and restored.
Pat
keepat
I've had a few people ask how I remove the paint, clean the metal and finish off the welds, so I thought I do little right up and some pictures on what has worked for me.
In the engine bay I have found a heat gun and wirewheel  on a drill works great removing  the paint and original primer from all the nooks and crannies. I like using a 12" quick change extension to hold the wire wheels. The advantage of the drill over a grinder is you can change the direction of the drill which allows the wirewheel to work more aggressively remove the paint and primer.  With the heat gun I blister about 6"x6" of paint and while it is still hot I use the wirewheel  to remove that section of paint, it goes quick and no fine dust.
Here is a before and after of the firewall using only the heat gun and wirewheel.
Here I'm welding over the wire harness plug hole. After tack welding the cover in place I grind down most of the welds before finishing the welding, this helps keep the heat down and make it easier to connect the weld as thickness of the metal is similar to the welds.
I like to use a 90 degree Die grinder with 2" 36 grit disc to take the welds down. Keep it moving and always use new disc when working small areas as worn disc will just heat the metal instead of cutting the weld down.  When the welds are mostly cut down you can hammer and dolly the panel flat and then finish off the leftover weld with a 60 grit disc.
Note before hammer and dolly the panel you will need to grind down the weld on the back side!
The last thing I do is use a 6" random orbital sander with a ¾" foam pad and 100 grit paper to clean the metal.
Pat
70mopar500
The guy's are right Pat, I get all giddy when I see you're thread in the unread posts  :woohoo: i was showing my son your welds. Now you see it, now you don't I makes me want to tare mine back down and start over.  :lol: I don't recall what you are doing for a elec set up. Mine needs it all and I am torn on stock replacement or painless system
Rich 70 charger 500 440.  07 Ram Quad cab 1500 5.7 HEMI, 80 Camaro RS 350
Rolling_Thunder
Thanks for the write up brother!   Really useful
I keep my car right off base (finally got out of the dorms) so my work will begin in a 2 car garage.
I'll definitely drop by sometime and check out the car! :2thumbs:
keepat
Quote from: Rolling_Thunder on February 21, 2016, 05:48:21 PM
Here's a picture of the 72 after he spent the last 5 years restoring it
keepat
Quote from: 70mopar500 on February 21, 2016, 05:04:03 PM
I get all giddy after posting the updates because it's usually at the end the day and it means I'm going to bed ;-)
I have yet to purchase a wiring harness yet as I'm hoping that the new American Autowire harness will be available soon for B bodes Mopar's.  I use their harness on my son's Mustang a few years back and I was very impressed with the harness and the connectors.  If it's not available by mid to late summer I may have to do some research on what others here have found to be a good wiring harness for a modified car?
Thank you for following the build and good luck with your project as well!
Par
garner7555
I ordered the American Autowire Highway 22 kit for my charger.  I know it's universal fit, but that also gives you extra wire length to hide the wiring on a build as clean as yours.    :2thumbs:    :Twocents:
69 Charger 440 resto-mod
keepat
Quote from: garner7555 on February 21, 2016, 09:38:57 PM
I may go with the same kit but I would like to have new original looking connector at the headlights and tail lights. The longer wire is a must as the lights, fan, and horn wires will run along the outside left fender.
Pat
Patronus
We're wiring up the Painless 22 Mopar version now. Also running up the fender well, etc.
Feed back is neutral. Apparently some circuits are combined that others may offer separate. For us this is a full LeD converison, adding about 8-9 circuits.
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
keepat
The paint is removed and all the unused holes are welded up in the engine bay and ready for epoxy primer.
Pat
keepat
I had a mold made of the front bumper guard mount so I could make a carbon-fiber version of it. The steel mount weighs about 6 lbs and the carbon-fiber replacement will weigh about 1 lbs. After I pull the 1st part I'll post a few pictures and if anyone is interested I could make a few more? I think I will paint mine black to look original but they could be left clear to show the carbon-fiber if you like?
Pat
WHITE AND RED 69
That is looking sweet Pat! Great work! Are you going to make any other parts out of carbon fiber?
I'd be interested in a carbon fiber mount. How much you thinking for one?
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
keepat
Quote from: WHITE AND RED 69 on March 01, 2016, 04:54:32 PM
I'm only going to make a few to cover the cost to make the mold and materials. I will know the price after the 1st part is pulled, but it should be about $165.00?? There are a few other parts I'm looking to make to help move the CG aft in this charger and this is the test part
Pat
mike69440
Quote from: keepat on March 01, 2016, 05:22:09 PM
Pat
Hollow front sway bar will take out some weight.
68RT440
I like the CF support brace. Great idea and it will look stock once painted black.
1968 Charger R/T, matching numbers 440/727, black with green top and interior, currently getting restored by me
70mopar500
Part does that bow tie fit. 70 as well?
Yes my 70 has one, it had the bumper guards that attach to the holes in the bottom.  (I kept it but not the guards, adds some beef to the supports.)
WHITE AND RED 69
Pat
Count me in if you go through with em. I'm looking for ways to lighten up my tank.  :2thumbs:
keepat
Quote from: WHITE AND RED 69 on March 03, 2016, 08:00:25 PM
Pat
Cool! Should have the 1st one laid up and out of the oven this weekend!
Pat
v21hemicharger
Pat
I'll take one and any other CF parts like that.  Mike
keepat
Quote from: v21hemicharger on March 05, 2016, 03:30:47 AM
Pat
Mike, awesome! I will keep you updated with the CF projects.
Thank You!
Pat
keepat
Not much to look yet the CF is all sealed up, vacuumed bagged and going in the oven for the next 24 hours At about  140°
Pat
keepat
Boxed in the upper core support, amazing how much stronger it is now. I think I could pick the car up from it! I will use it run and hide the wires for the fans, horns, AC,  and lights.
Pat
Made tool to roll the top edge of the core support right at 1"
