Metal-
Started by DonC1, April 11, 2014, 08:18:19 PM
talkiemopar
Hi,
I have an NOS Bird wing center blade.  I would probably take $1000 for it.  If no one here is interested I will be putting it on e-bay with that as a starting price.  I plan to put it on in a couple of weeks. It has all the extrusion marks.
Let me know if anyone here is interested asap.
Rick
859-757-3645
pettybird
Quote from: Stevearino on April 27, 2014, 02:47:45 PM
Mike, Next time give me a little more detail on the process. :lol:
Don't you hate it when someone just phones in an answer like that?
I'd seen the first way on TV (on How it's Made, for instance) but hadn't heard of the second.  Would be pretty wild to watch...
I checked with several local aluminum extrusion companies a few years back (apparently I live in the extrusion epicenter) about making center sections only. The biggest issue was that the large machines necessary to make a 7" wide wing are much harder to find and much more expensive to run. The solution was to split the wing down the middle lengthwise (about where the center brace is) and make 2 halves with dovetail joints. The joint was barely noticeable but, to make it disappear, they could run a tig weld on each side after the halves were joined. Obviously, each operation costs money so, instead of a single extrusion with a bunch of band saw cuts, there were now 2 extrusions, cuts, an assembly of the parts, and 2 tig welds. Still came out cheaper than the one step process! The biggest costs were creating the die(s) and setup time on the machine(s). In any case, the price I was given was much cheaper than what Mike alluded to BUT the minimum order at any company was 2,000 pounds of material (4,000 at some). I calculated the potential market and decided there was no way I could sell all the wings I'd end up with and I'd have to find some place to store them or some other application (ricers?) to keep from having to throw most of them away. For the small number I could sell, the price would be so high that my potential market would decrease drastically. If an "insider" could get say 200-300 pounds at a time the die and setup costs would still be manageable.
Stevearino
We got Dane who makes great Daytona wings for what I think is cheap considering the effort and now Don C will have a nice Bird version. I think the limited market is now well served on nice aluminum wings. If we could only get someone to reasonably produce a correct piece of tempered rear glass of the Daytona I think we would be making some progress. I know new glass is available for the Vega but once you see a nicely done correctly shaped rear window plug it is hard not to want the real thing. :pity:
DonC1
Thanks Steve.
Daytona Scoops done - Cast aluminum.
DonC1
Dodge Boy
BigBlockSam
wow real Nice. did you contour the bottoms to match the fenders? the stinger ones were not contoured or have the mounting buns.
DonC1
Yes all the contours are there.  ;)
DonC1
Troy,
I'll be casting my next wing blade in two and tig welding both pcs as you would have. This blade is cast in one piece and steps in at 33lbs.Both my hollow uprights combined come in at 30lbs. I'd like to drop the blade weight down some next time. However it is still a nice piece.
DonC1
Bird fender scoops
 awesome work !!     :bow:    this is good stuff    :drool5: :2thumbs:    :popcrn:
DAY CLONA
Quote from: DonC1 on May 31, 2014, 12:17:46 AM
Troy,
Don, 63 lbs total is fine, as the originals come in at 57-60 lbs total...nice work, a bird wing has been needed for years in aluminum
Mike
Indygenerallee
Don, How much for a set of those aluminum Daytona fender scoops?? Look killer.
BigBlockSam
excellent work  :cheers: :cheers:  , those fender scoops are awesome
oldcarnut
Quote from: Indygenerallee on May 31, 2014, 04:48:13 PM
from the classifieds
http://www.dodgecharger.com/forum/index.php/topic,110535.0.html
odcics2
Quote from: DAY CLONA on May 31, 2014, 04:26:55 PM
Troy,
Mike
Curious, what's the difference in weight between the very early production Daytonas that had the solid horizontal stabilizer and the later ones, which were hollow?
DonC1
Ongoing...Daytona cone in 18 gauge
wingcarenvy
Mind blowing! I think you have a budding business opportunity.
BigBlockSam
 :faint:  wow , awesome   :cheers: :drool5: :popcrn:
moparstuart
Quote from: DonC1 on April 24, 2014, 12:30:09 AM
Off to the foundry tomorrow for a fresh batch of Daytona and Sbird aluminum fender scoops to be cast- these are the ' plugs'
( Stuart- haven't forgotten about ya:)
i want daytona ones please
DonC1
Catchin' up...
Z bars still have some holes to drill...
Dodge Boy
