hi beams issue
Started by Sgtmajor, February 09, 2014, 06:23:17 PM
Sgtmajor
Rerunning lights only light issue is when I use the dimmer switch my low beams turn off and no high beams either new hi beams lights or dimmer switch. Open to suggests.  Being replacing many bulbs.
twodko
While I loathe throwing money/parts at a problem that I don't know the cause of, buy a new dimmer switch. They're cheap and who knows.........
RJS
Quote from: Sgtmajor on February 09, 2014, 06:23:17 PM
I'm not sure if your asking if you need new lights or dimmer switch or if you already changed those???
If you didn't the dimmer switch is usually the culprit but Headlight switch could also be cause.
I went through this last summer with my Demon. it was right at the bulk head (engine side) bad crimp at the wire that brings power through.
Use a shop manual and follow the wire diagram.
Sgtmajor
Looking for ideas what the issue could be. Really would like for weather to be better, got time in today rain next 3 days.
1974dodgecharger
dont use high beams and drive without them and not stress?  I could stress out about having no ash try, but as long as my car is mechanically sound and body in good shape I say forget little things such as that?
That or go buy new high beam switch as members suggested and look at the wiring diagram.
When I took apart my 68 I drew a map for my personal records where the main power lines g, whats connect, etc...
Quote from: Sgtmajor on February 09, 2014, 09:36:19 PM
issue could be:
bad dimmer switch
all high beam elements burned out
faulty wire connection at dimmer switch
faulty wire connection somewhere under hood.
you can probably rule out the headlight switch itself, seeing as the low beams work
Patronus
I would recommend a test light and the ol pokie pokie
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
six-tee-nine
Quote from: Patronus on February 10, 2014, 12:01:52 AM
the ol pokie pokie
Definatly do that first..... still helps me find alot of problems even in today's computer diagnostic era......
Mytur Binsdirti
The ol pokie pokie works well on high beams.
Firewall disconnect ...clean the terminals.
BTW, these are high beams.
Tilar
Quote from: John_Kunkel on February 11, 2014, 01:24:39 PM
Umm, I believe we have a winner.  :2thumbs:
Dave
bill440rt
Please pass me the test light. And quickly.  :cheers:
