High Beams
Started by HeavyFuel, January 29, 2014, 01:39:38 PM
HeavyFuel
Not these.
To help correct the dim road created by the woefully inadequate headlights on our cars, has anyone tried aiming the 'brights' down a little bit, and running with four lights on instead of just two?
I think that might be worth a try.    :scratchchin:
It seems like sound advice. :yesnod:
Cooter
Even aimed down, the high beams are brighter. I see a ticket and or many middle fingers if implemented...
seeing as how the headlights are hidden on these cars, I'd be looking into some brighter low beam lamps.
twenty mike mike
The gendarmes will take a dim view of your plan.  :rotz:
I'll do this eventually, after I make the appropriate wiring modifications.
http://www.amazon.com/HELLA-002850811-Halogen-Conversion-Headlamp/dp/B001G7A9YS/ref=pd_sim_sbs_auto_1/190-7514767-0267933
bill440rt
I put a set of Hella's in my '68. Plug-n-play. Huge difference. Next best thing to the xenon conversion kits IMHO.  :yesnod:
XH29N0G
Quote from: bill440rt on January 29, 2014, 09:03:55 PM
Are these easily found?  I just did a quick search on the Hella web site and wasn't successful.  I could need a  :slap:
Or maybe it protects us.
I got Sylvainia or Wagner halogens in mine...drop in replacement and they even draw less amps then regular sealed beams
twenty mike mike
Quote from: XH29N0G on January 29, 2014, 09:18:41 PM
http://www.hella.com/hella-us/951.html?rdeLocale=en
http://www.myhellalights.com/pdf/2012_HELLA_INC_Accessories_Catalog.pdf
Page 77, Conversion Headlamps. You'll want the H4 bulbs, Page 107. Don't touch the bulb glass with your fingers, since your skin oil will cause a hot spot when they're on and cause early failure.
Entering "Hella H4" into your favorite search engine will result in dozens of hits.
69white hat
I just bought a complete hid kit from blinding hid, comes with every piece you need. Should have a nice modern look and be bright going down the road.
XH29N0G
Quote from: twenty mike mike on January 29, 2014, 09:53:40 PM
Thank you.  guess I did need a  :slap:  This helps.
66FBCharger
Quote from: twenty mike mike on January 29, 2014, 08:43:51 PM
This sounds like a great mod. What wiring mods need to be made to use these headlights?
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
Dropped halogens in mine and doubled the output.  Probably the cheapest, quickest and most effective mod ever!  I can't wait to get it running again so I can see the relay mod at work.
I'm actually thinking of getting rid of the inner light and replacing them with the outer lights so I have 4 low and 4 high beams.
twenty mike mike
HeavyFuel
Quote from: Cooter on January 29, 2014, 07:24:11 PM
Yeah, I forgot about the brightness, was just thinking aim.    :rotz:
HeavyFuel
Quote from: Dino on January 30, 2014, 08:21:23 AM
Um...I'm not trackin'.  :shruggy:
Additional wiring needed?
Quote from: HeavyFuel on January 30, 2014, 03:02:00 PM
Sorry, I wasn't clear.  That happens.   :icon_smile_big:
Instead of having 2 low/high beam headlights  and 2 high beam headlights, why not use 4 low/high beam headlights?  All 4 are on when the lights are on and all 4 go to high beam when you hit the foot switch.  All that would be needed is to add wires for the additional low beams and that's easy enough, even if you use the relay mod.
I don't see why that would not be a major improvement over the stock system, then again I don't see everything either.   :lol:
you will need to get the buckets that the lights mount to..you cannot put a low beam light into a high beam mounting pod
Quote from: A383Wing on January 30, 2014, 04:12:14 PM
Thanks for letting me know, I had no idea!   :2thumbs:
I'm pretty sure I have a full set in my spare grille and if not they're easy enough to find.
Would you happen to know if you can mount the low/high beam pod in the high beam pod's spot without mods?
I don't know about the second gen cars...I do know I could not mount the hi-lo pod in the spot where the hi pod is on a first gen Charger....mounting tabs were in different location, and it would have been real hard to try to change it because they mounted into the pot metal headlight housings.
Second Gen might be easier because of mounting to sheet metal
Quote from: A383Wing on January 30, 2014, 04:28:03 PM
That's probably true.  I love customizing but at this point in my life even the small projects take me a long time.  A day is only so long and I need my beauty sleep...or coma...
myk
Driving with your brights on is unnecessary.  Install fresh wiring, perform the relay 'mod and possibly a higher 'amp 'alt and you will never worry about inadequate, dim headlights again.
HeavyFuel
Quote from: myk on January 30, 2014, 08:16:44 PM
I just got my car "done", not about to rip into it to do the relay mod.
The wiring is new, the alt is new and tested at 64 amps @ 2400 rpm, 93 amps at 7500 rpm (like my engine will ever hit THAT).
Just thought there might be an easy way to pick up a few candlepowers on the cheap......plus I thought it might look cool two have four lights burning up front instead of just two.
Plumcrazy
Quote from: 69white hat on January 30, 2014, 01:21:07 AM
What you are going to have is a lot of light that is scattered all over the place. The sealed beam conversion housing will not focus the light output properly because they are designed for halogens.
HID bulbs emit light differently than halogen bulbs and the housings must be designed for them.
myk
Quote from: HeavyFuel on January 30, 2014, 09:24:44 PM
With all due respect, I don't understand.  If the car is "done" and it isn't to performing to your liking then the car isn't "done."  I'm assuming your car is built up to stock 'specs and if that's the case, there's nothing you can ever do with that car in its stock configuration that will allow you to have headlights that  equate to a modern, USABLE standard, without the relay 'mod or modernized electrics.  If you want your car to perform to the higher standards that we've become accustomed to with modern automobiles you will have to modify your car's systems to some degree.  You could drive around with your hi's, but there's a better way to see more on the road, IMO...
HeavyFuel
Quote from: myk on January 31, 2014, 07:39:39 AM
You make some good points.
Probably spring for the halogens, like Dino said, they are plug and play.
No need for relays for the hals, correct?   Stock wiring should be enough to power 'em?
