best front disc brake kit
Started by Al, December 31, 2013, 08:31:03 AM
Al
After a dangerous braking situation with my Charger's drum brakes last summer I decided to replace the front drums with disc brakes.  I would like to go for power front discs.
There are a lot of posts on disc brake kits and I have read most of them. However I cannot make up my mind on choosing one particular kit. Often the appreciation of some of them is quite contradictory. Because good brakes are so important, I want to make the right choice and not regret it later.
So far from what I have read here, MP Brakes seems to be a good choice. Is that correct?
Or are there other suggestions?
Any Feedback would be greatly appreciated.
Al
1968 Dodge Charger, 383, UU1
Mopar Nut
What size wheels are you using? Some disc brake kits don't work with smaller wheels.
Al
Silver R/T
This guy used to have a kit that has brackets which just bolt onto your factory spindles (supposed to keep same height)
Pricewise it was $360 + shipping, of course it was a while ago. This is kit that I'll be ordering for my charger. It works with 15" wheels. You'll have to contact him to see if he can get you a kit for your Charger.
http://www.ebay.com/usr/mgchevyparts
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Lord Warlock
MP makes a nice kit, based on 76 aspen single piston caliper brakes.  I bought one of them, but never installed it, chose to rebuild the stock brakes instead.  One of these days I'll box it all up and sell it off.  There seems to be quite a few companies that do brake kits these days.
Al
Is there anyone who has used the MP front disc kit for more than a year and willing to share his experience?
greets
Al
Al
Mr. Lee
If I can hop in on this topic, wich disc brake kitt will work for the 14x7 Vector wheels?
Thanks  :2thumbs:
el dub
I have the MP disc brake setup on my car. Stops better than it did with drums by a long shot. I did put an adjustable proportioning valve in the circuit as my rear drum brakes were locking up first. lw
NHCharger
I bought a front disc brake kit from Fine Lines at Carlisle last year. Still haven't got my car on the road yet but I have to say their customer service has been top notch. they promptly answered any question I had during the install and shipped me out some new brake lines  when the ones that came with the kit were 4" too short.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
As far as I know there's nothing other than the stock 1960's factory discs that clear 14" wheels.  The aftermarket & hi-po world already regards 15" wheels as ridiculously small these days.
Mopar Nut
Quote from: Mr. Lee on January 10, 2014, 03:42:40 PM
Thanks  :2thumbs:
I have Baer disc up front with 14" wheels now, i'll look to see the model.
Al
Quote from: el dub on January 10, 2014, 08:00:22 PM
Where did you install the adjustable proportioning valve? After the factory proportioning valve i.e. on the brake line to the rear Brakes?
Bob T
Quote from: Mike DC (formerly miked) on January 10, 2014, 09:41:22 PM
Maybe the 74 Dart? I was talking to a mate at the drags today, he upgraded his 68 440 drum Coronet a while back, I'm sure he said 74 just bolt on, didn't have any problems with the valve too , I seem to recall, it was a while ago though...
Old Dog, Old Tricks.
NHCharger
Quote from: Al on January 11, 2014, 04:14:18 AM
Yes. On the kit I got they supply you with a 12" brake line the goes from the factory prop valve to the new prop valve for the rear brakes. I bought all new SS brake lines also, cheap insurance.
Thanks  :2thumbs:
Read through this: http://www.moparaction.com/Tech/archive/disc-main.html
bill440rt
I've had an MP manual front disc kit on my '68 going on 3 years now. Easy to install.
I did experience rear brake lockup at first, however the pads on the front need to be properly embedded & broken in. After a series of test panic stops (back roads, open areas here), the rears do not lock up anymore. I merely had to install a repro disc prop valve in. You can either modify the front/rear line, or get a new front/rear disc line.
Only problem I had was a pesky leak at the fitting where the hose attached to the driver's side caliper. MP swapped them twice, last caliper just had the teeniest leak. Doubling up on the copper washer did the trick. MP said they had seen this problem before, only with the driver's caliper. So, if you go this route just keep a close eye on leaks when bleeding.
Car stops MUCH better compared to the drums. I'm happy with the kit.
Al
Quote from: bill440rt on January 11, 2014, 10:12:10 AM
Do your MP Manual front discs stop significantly better than the original drum Brakes?
bill440rt
It is a noticeable improvement. It is on par with factory discs, as the MP kit is based on stock parts. Parts are new also, not refurbished which also appealed to me.
You'll have to run a 15" wheel. I have 15" Centerlines, and also had 14" Magnums for the car. I sold off the 14" Magnums & bought a 15" set which are on the car now.
Al
Quote from: bill440rt on January 11, 2014, 12:30:35 PM
Do manual disc brakes give enough breaking power as compared to power discs ?
el dub
Al
Quote from: el dub on January 11, 2014, 01:47:46 PM
What does your first post say? :icon_smile_big:
I initially planned to change from manual drum brakes to power discs. But Bill seems to be saying that manual discs are great too. So my thought is: maybe manual discs are enough, cheaper and no there is no need to replace the mastercylinder and install a power booster. Hence my question. In other words are power disc brakes necessary ? :coolgleamA:
el dub
Sorry, my fault. I wasn't reading correctly, I've got power disc brakes.
bill440rt
I should have been more specific as well.
The car is a manual brake car, I kept manual brakes due to the low vacuum producing cam that's in it. I also did not want to install a hydroboost, as the engine compartment is very stock appearing.
The manual disc brakes perform MUCH better than the manual drum brakes. The six-piston Wilwoods I have on my '69 with the hydroboost perform MUCH better than the manual discs, which is no surprise.
In short, yes it's an improvement. I don't mind the manual disc brakes. The car stops easily to me. I see no reason to put in a booster.
If you feel you need one, you can always install a booster. MP sells them separately.
