painting vin tag
Started by thebigmope, December 01, 2013, 08:42:40 PM
thebigmope
I am currently restoring a 1968 charger before i install the windshield i would like to restore the vin tag does anyone know what type of finish this tag should have? (gloss, semi gloss flat ) thanks, John
cdr
bill440rt
 :yesnod:
VIN tag should be slightly glossier than the dash frame, there is a contrast in color.
Just did this on my '68. Dupli-Color Semi-Gloss black was a very good match for the tag, dash frame was refinished using SEM trim black.
thebigmope
Thanks for the reply i found the dupli color and i got the transfer , John
