New Cam ...more vacuum = higher oil consumption ?
Started by Big Sugar, November 21, 2013, 10:45:30 AM
Big Sugar
Hey Folks
Swapped my cam out last spring to a newer Lunati 603 from a Mp. .509
My vacuum went fron below 10" at idle to 15"+ at idle.
The 440 is running great but this year the engine has been going thru oil !
ive done a lot more driving at higher RPMs this year 31-3500 rpm just because the power band is so smooth in that range where as before I tended to stay in the 28-3100 rpm range.
Im using about a quart per tank , the plugs were nice last time I checked but as the weather got colder in the fall the car became a little stinkier at the exhaust.  no leaks and no blue smoke ?
Could the higher rpm and higher vacuum be causing the higher oil loss ?
Im running a six pack setup with a pcv and oil vapor line to the breather, have noticed a bit more oil seeping around the six pack breather trim, at the base .
[img]<table border="0" cellpadding="0" style="border-collapse: collapse" width="182" id="table1" height="202" bordercolorlight="#ECEBF1" bordercolordark="#E9DFD1" b
Higher vacuum should not be causing increased oil consumption...at least not if it's a ring problem. Higher vacuum should be helping with ring seal...not hurting it.  :scratchchin:
Might be time for a wet/dry compression test fallowed by a leakdown.  :yesnod:
Have a look again at the plugs for signs of oil burning. It could be coming in through the valve seal(s) or an intake port(s).  :scope:
I'd also look at the PCV valve....it could be defective.
Are the valv covers baffled? If not, could be sucking it through the pcv
