Pcv to air filter base.
Started by 1974dodgecharger, November 15, 2013, 11:57:35 PM
1974dodgecharger
Is it ok to connect the pcv to air filter base plate? I don't have any ports on my 750 dp for connection.
I noticed my car does not stink as bad when I do this.
cdr
it needs to be hooked up to manifold vac,then off the other side can go to the air filter housing.you may have to drill & tap the intake for a fitting.
1974dodgecharger
Cdr,
Alright man, just don't want to take apart the intake a lot of work for me, for now that is.  Just want to enjoy her for the winter till I kinda out her away for summer next year.
If your carb doesn't have a PCV nipple and you don't want to drill out the intake manifold ; the easiest way to do this installation is to get yourself a carb spacer and drill/tap then install a vacuum nipple. A 3/4in open plenum aluminum spacer will do the trick.  :yesnod:
1974dodgecharger
Quote from: firefighter3931 on November 21, 2013, 10:18:22 AM
Now that something i can do in 30mins instead of taking the whole manifold out etc...thx firefighter.
Quote from: 1974dodgecharger on November 21, 2013, 10:55:38 AM
Exactly....quick and easy and should cost less than $30  :icon_smile_big:
You're welcome  :2thumbs:
cdr
RON is correct,but check your hood clearance 1st,thats why i said to drill the intake,most of us have hood to air filter problems. :Twocents:
