RB lift in place
Started by greenrt_se, August 07, 2005, 02:04:07 PM
greenrt_se
Best place to lift 440 back to engine room,Carb threat or from head(passanger front /driver back) head are edelbrock Aluminium
Runner
i like a lifting plate on the intake manifold carb mounting flange.
I usually use the 3/8" holes at the front & rear of the heads
rebby
Quote from: Chryco Psycho on August 08, 2005, 02:23:10 AM
Ditto. It has worked very well for me in the past.
Curt Rebelein, Junior
1969 Charger R/T SE (500 Stroker/833/D60 w/XP VIN)
1969 Charger (440/727/8.75, GL Project)
If i'm pulling just the engine the carb flange plate works fine. When i do an engine-tranny pull i like to use a load leveller which has a 4 point attachment and makes things a lot simpler/easier. The load leveller allows you to adjust the angle while everything is still loaded on the crane.  :thumbs:
