Transmission leak
Started by Lee A, November 05, 2013, 04:16:58 AM
Lee A
Hi I have a leak in my tranny it's in the back side where the driveshaft goes in I replaced the seal but it continues to leak did I miss something it's on a 68 dodge charger 727 automatic tranny
1968 Dodge Charger 440
1969 Dodge Charger 383
cudaken
Could it be the shaft that goes through the seal is worn to much?
I am back
fy469rtse
check the condition of the slip yoke as well,
if it has groves worn in it, from years of use, it will just tear the new seal out
Hard Charger
is the new seal the correct one? installed right? (no offense)
don't they install like a axle seal. I have only needed to install one in 30 years, so lets say we may not be experienced in this.
68 727's have a longer tail stock. is the tranny original to the car?
There is a soft plug that seals the end of the slip yoke, on rare occasions it will leak.
Clean the area thoroughly with brake kleen and try to determine the exact source of the leak.
Lee A
The tranny was put in 1971 from the second owner it hasn't been looked at since besides me putting a pan seal in and that tail seal the kick down has never worked maybe it's time to get it rebuilt or would you guys get one from summit racing
