i need new wiper transmissions, i cant find any
Started by miller time, October 04, 2013, 06:19:51 PM
miller time
are the wiper transmissions reproduced or where can i get a decent used set? mine are seized and i know they fit quite a few year, or are there any wiper transmission i can modify to make work? i found a set but i dont really want them, much rather get them new if i can, my are completely seized up if i can rebuild them please tell me how, thanks
and if this post should be elsewhere please tell me because i need to figured it out ASAP
Cooter
Sho nuff. Ii would think any B body wagon, four door, 2dr would work from 1968-1970.Charger, Coronet, roadrunner, GTX, Satellite, Belvedere...
bill440rt
I've had luck unseizing them by soaking them in penetrating oil for a few days. Put the housing in a vice and tapped gently on the mount pivot area. Soak some more, etc.
Eventually they moved freely again, some did not.
Worth giving it a try.
If not, yes any '68 - '70 B-body should be interchangeable. No repros AFAIK.
Cooter
What Bill said...I have free'd with a little heat too.
miller time
thanks, i already sheared one in half by tapping it with a hammer, it moved, just the wrong part moved lol
im going to aleast 1 junk yard tommarrow to look for them
Did you ever find anything? I have a pair off a 70 Charger 2 speed wiper setup.
