Map light option
Started by RGA, September 27, 2013, 11:02:34 PM
RGA
I was trying to figure out why my map light didn't work and took it out. Found out there is no connection, no light socket, and no wiring to the light. Weird, all my wiring looks factory and perfect under my dash but there is no wires run to the map light. Were these an option ? Maybe mine didn't have one and someone added it?
They were an option but you'd think if someone added it they'd grab the wiring and stuff too.
8WHEELER
Does it have an ignition key light? that is part of the same light package as the map light. The light
will come through the hole just above the key.
Dan
Also look for glove box light, trunk light and ashtray light.  If none of the above are present then someone swapped the delete plate for a light cover.
RGA
Yup, there is a hole above my ignition cylinder but no bulb, switch for the glovebox light but no wiring there either. No ashtray light. Wierd. Man those lights would be nice, never thaught about it till now. Guess I got the supper base model RT
daveco
I guess another possibility is that the wiring harness has been replaced.
R/Tree
moparfan53
 Don't know what year you have, but here is the 1969 light package components. Some years the components would change slightly. You will see it specifies that the components are only available as part of the package.
:cheers:
rave_12000
Someone probably just wanted to pretty it up with some bling bling.  I have some extra wires laying around...maybe
Brock Lee
Your fender tag will have A01 on it if the car had the light package.
RGA
Fender tag and build sheet were missing from my car, sucks cause guy said it was an original six pack car but no way to tell. I am how ever interested in that extra wiring ?let me know if you have it, would probably plug right into my factory harness
I believe you have a 69, do you not?  There were NO Six Pack Chargers in 1969.  Your engine designator is in the VIN, it will tell you what the engine was for it.
just for reference , heres the A01 light group harness  , & ive labled whats what
moparfan53
Quote from: RGA on September 30, 2013, 07:33:06 PM
As Ghoste already said, the vin is a way to tell what the original engine was. The 5th digit is your engine code.
moparfan53
Quote from: tan top on October 01, 2013, 04:18:33 PM
Thanks, great reference info for future use!  :2thumbs:
stripedelete
Did A01 not include a trunk light?
RGA
Thanks for the info, awesome. Do you know if anyone sells the harness pigtails and lights ?
RGA
Quote from: Ghoste on September 30, 2013, 07:46:51 PM
I do have a 69 rt vin says 440. I was told different on the 69 six pack thing though. I'm sure you know more about than me.
The Six Pack wasn't available in a Charger until 1970.  In 1970, a "U" meant 440 four barrel and a "V" meant six.  For 1969 an "L" meant 440 four barrel.  Halfway through 1969 the 440 Six Pack became part of a package for Super Bees (and Road Runners) and they had an "M".
dodge604charger
Thank you tan top. Answered alot of questions with those pics
