741 to 742 swap
Started by Dreamcar, September 15, 2013, 05:00:24 PM
Dreamcar
Hi. If I want to change to from a 741 to a 742 diff, can I just swap the cases or do I need to get the entire rear axle assembly? It appears to be easier to get gears/parts for the 742, but I've got a complete 741 rear axle. I plan on having everything rebuilt anyway.
Having to ship or transporting just a case is much easier than the entire rear axle.  :2thumbs:
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
What year? If it's '64 or later you can remove the 741 3rd member and replace it with a 742 3rd member....if it's '63 or earlier the same swap could require an axle shaft change.
Dreamcar
Its a 69 so that's great news. Thanks
The u-joint may be a different size though so measure before install in case you need to go buy one.
Dreamcar
Quote from: Dino on September 16, 2013, 06:47:12 AM
Good to know. Thanks!
flyinlow
742's Suregrips have a button in the bottom of the axle well that the two axles press against to set the end play.  Make sure the carrier still has that  unless you are going to run "green bearing" on your axles.
Dreamcar
Quote from: flyinlow on September 16, 2013, 08:23:20 AM
You've lost me since I know very little about axles...all I know is that I'm buying a 742 case (found a non-sure grip with 2.76) that I was planning on having rebuilt with 3.55 gears and limited slip...Are you saying that I may not be able to?
flyinlow
No it will work. If the 742 was a factory suregrip there are two buttons that the SG unit uses. I got one once and they where missing. can't set the end play without them.If you are going to have it rebuilt and the limited slip unit added ,they will take care of that for you.
flyinlow
These are the buttons
Dreamcar
Quote from: flyinlow on September 16, 2013, 04:16:54 PM
Perfect! Thanks
Cooter
Also, ill add that even with big joint on shaft, small joint on chunk and vise versa, you can purchase what is called a combination joint round here to make it all work...big on one side and small on other. I used to have the number but can't find it now..
Dreamcar
Quote from: Cooter on September 16, 2013, 06:47:52 PM
More great info. Thanks
