Don's 69 Charger Rust Belt restoration
Started by mopar4don, September 01, 2013, 08:34:55 PM
mopar4don
pic1   I then inserted the tube into the column and slid the spring over the end
pic2-3     then I slid the lower bearing on and bolted it up
mopar4don
Next I inserted the shaft. Don't do it like I did or you will have to unbolt the lower bearing and slide it over the shaft and then re-bolt it to the column (because of the drive dogs on the shaft)  :brickwall:
mopar4don
pic 1    This side of the column is most of the work
pic 2    First the lower collar goes on
pic 3    then the upper
pic 4    here are the parts we need to assemble
mopar4don
pic1     start with the c-clip (this helps to prevent the upper bearing from going to far)
pic2     next on is the upper bearing. (I applied a light coat of grease to help it slide)
pic3     next I carefully tapped the bearing into place.
           In this pic I used the old bearing against the new bearing along with a deep well socket, this way I was pushing on the inner race.
mopar4don
pic1-3    next is the upper retaining clip
pic4       then the bearing insulator goes on over the bearing
pic5       next is the hardest part! bolting the collars together. This may take a lot of trial and error to get it right
mopar4don
pic1   then the turn signal switch goes in held by the retainer
pic2   next I put the wire cover on
pic3   and the lower black plastic cover
mopar4don
Now for the wiring the new plug.
I referred back to pics I had when I disassembled the plug and to be absolutely sure I looked at the schematic to be sure the way it was correct!
mopar4don
pic1    Then I bolted on the column bracket
pic2    and put on a temporary steering wheel and the firewall bracket and wrapped it up in plastic and put it away for safe keeping.
          I will put the rag joint on when it goes in the car.
CDN72SE
1972 Charger SE
VegasCharger
Quote from: mopar4don on July 25, 2018, 10:22:21 AM
Boy, ain't that the truth!
Nice work Don. :2thumbs:
mopar4don
Here are some before and after pics of the door mechanism hardware.
I used Evaporust to clean them up. To finish them off I touched them up with steel wool, and coated them with RPM
mopar4don
I started the tear down and restoration of my grill. This is what I started with.
It looks good from 40 feet, but it has some problems that need fixing.
mopar4don
more...
mopar4don
I have an extra set of doors, but as you can see, the drivers side stops are broken off. From what I understand this is a common problem.
Apparently with the weight of the badges its to much and eventually they break off.
timmycharger
Good starting point on your grille!
Check out page 10 of my build, I used methods I found from here on the site!
http://www.dodgecharger.com/forum/index.php/topic,119572.0.html
mopar4don
Thanks timmycharger, I will check it out
Stevearino
You are leaving no stone unturned Don. Very thorough . :yesnod: :yesnod: :yesnod:
mopar4don
Here is a pic of the pass side bucket and where it broke
mopar4don
So my plan was to prep all of the plastic pieces (I used a dremel to 45 all edges and crack lines. I also drilled a hole at the end of the crack. This will stop the crack from continuing) and then to create a slurry using ABS shavings and acetone. Then using the slurry to fill in all of the cracks and holes.
timmycharger
 :cheers:  Great idea with the holes and using the dremel!  With the Slurry, if you can find an air tight container, you can leave it in there and use it later on as it will still stay fresh as long as no air gets to it.  :Twocents:
mopar4don
So i had some problems with the ABS slurry not sticking to the original plastic. And had to come up with a new plan.
Other people have used a 2 part epoxy with good success, so after a friend recommended 3M semi rigid plastic repair
I went ahead with it.
mopar4don
I started with the easy areas and gradually worked up to the harder spots.
mopar4don
So the drivers side bucket was a challenge. It had a piece that was completely broken.
pic1
The challenge was how to hold it at the 90 degree end
seen in pic2
