Don's 69 Charger Rust Belt restoration
Started by mopar4don, September 01, 2013, 08:34:55 PM
mopar4don
looks pretty good
mopar4don
(pic1) Now it's time to cut out the old
(pic2 and pic3) and put in the new (after a lot of fitting)
(pic4) here it is after it is welded in
Overall it turned out pretty well  :2thumbs:
cdr
keepat
mopar4don
Thanks for the compliments CDR and keepat!  :yesnod:
CDN72SE
1972 Charger SE
Stevearino
Don by the time you are done this car you will be good enough that the only thing you will need to build your next Charger will be pallet of  flat sheet metal. :2thumbs:
Bronzedodge
This is my favorite thread on the whole board, hands down.   :2thumbs:
Mopar forever!
alfaitalia
Great skills there. Beats all the cheese section cutting and welding I would have done to do a similar job!
Nice to see this stuff Don, too many nowadays think that if the part can't be found in an AMD catalog then the car cannot be fixed.
mopar4don
Thank you very much guys! I am truly humbled by the kind words! :blush2:
There is a draw back to my approach. And that is it takes a newbie like me a long time, but on the up side, it is a whole lot cheaper!
jwells1993
keep on keepin on
VegasCharger
orange383
Quote from: mopar4don on October 03, 2017, 11:38:26 AM
And very satisfying too I should think. You did a great job there. Thanks for sharing your knowledge Don.
Pat1973charger
mopar4don
Ok next area to fix on these fenders is the front nose.
Stay tuned.......
Harper
Mr you are my HERO!!! thank you for all of your hard work and dedication in posting pictures of each step of this!!!  :cheers: :drool5: :2thumbs:
1968 Dodge Charger
1969 Dodge Charger (GL Clone)
1951 F1 Ford 302 EFI, Automatic
1965 F100 Ford Straight 6, 3 speed on column (all original)
mopar4don
So what I have is one fender with the nose a bit to blunt (passenger side)
pic1
And the other (driver side) that is just a mess and needs a lot of work (surprise surprise)
pic2
mopar4don
I had previously removed the headlight bucket support (pic1)
and because I want NO rust, I went ahead and removed the inner antenna support (pic2-3)
and wheel well brace. These will get blasted and repaired if needed (pic4-5)
keepat
mopar4don
mopar4don
So I figured I needed some templates to help me fix the nose of these fenders.
I have another fender that has a good nose so I layed out a grid on it and made templates that would match each grid line or section line. Sorry didn't get a good pic, but you can kind of see the grid in this pic
mopar4don
Next I made the templates (each one corresponds to a section line)
mopar4don
I then transferred the grid to the fender
