Don's 69 Charger Rust Belt restoration
Started by mopar4don, September 01, 2013, 08:34:55 PM
mopar4don
The other side was good
Wow I am tired thinking about all that!  :icon_smile_cool:
mopar4don
So here are a few pics of the cowl getting undercoated
mopar4don
and welded in
mopar4don
I also rebuilt the rear quarter window regulator assemblies
This is a before
mopar4don
All the parts
mopar4don
pic1 I had to remove this roller
pic2  Took a punch and quick hammer strike pushed the pin out of the roller
pic3 removed
pic4 A c-clamp pushed the new roller on
pic5 all assembled
mopar4don
The only problem or question I have is with this roller.
The original is on the left, 2 new ones in the middle and right.
You can see how the new ones are longer than the original and the undercut groove is higher than the original so when you snap the retainer in there is about a 1/16 gap.
So that roller can move up and down by that gap amount.
Maybe it doesn't matter? Or do I need to put a washer in there?
VegasCharger
Quote from: mopar4don on May 11, 2021, 02:22:47 PM.....So that roller can move up and down by that gap amount.
Maybe it doesn't matter? Or do I need to put a washer in there?.....
First off, nice progress on the Charger. :2thumbs:
On the repop roller, man that sucks it being off from the original.
May I suggest that maybe use some sort of plastic bushing/washer to fill the gap??
:cheers:
mopar4don
Quote from: VegasCharger on May 11, 2021, 11:30:35 PM
:cheers:
My thought exactly. I was hoping someone else had run into this problem and could comment on if it is a problem.
Maybe it does not matter?
bakerhillpins
Don't you just love this kind of stuff... From my vantage point I'd leave it alone but I don't have the full picture either as I've never done a teardown/rebuild on one.
  • One thought - it's entirely possible it's a updated part in later models that was a suitable replacement for the older style.
  • Pin length: Can you elaborate on how the pin and rollers are placed in the final assembly? I believe the "lower" roller is fixed on the shaft correct? It may be that the pin length is irrelevant because the "upper" roller is effectively held in place by the channel. Thus the extra length will never carry the roller as it will not slide laterally. So as long as the pin doesn't interfere with any other part of the mechanism it's fine.
  • Undercut grove - I see what you're saying but I think that the roller is also wider. It appears that the "top" surface is not flat (tapered down to the shaft) where the OEM part is flat sided. as long as the bearing surface is the same under the roller (can't see but I suspect it is) I wouldn't be concerned.
  • Reuse? - If you carry some concern grab some calipers/magnifying lamp and take a quick look at the shaft diameters/condition. My suspicion is that you could reuse the old pins with the new nylon rollers. I'd expect the nylon, which is softer than the metal pin, to be the wearing item. Though if it got filled with hard grime that might cut into the pin.
A few thoughts anyway.  You've done amazing work!
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
armor64
when i rebuilt mine a few months back, the longer shaft didnt matter, it gave the assembly a slight amount of side to side wiggle room, which seemed to make it easier to assemble in the quarter. when it was all lined up and bolted down, there was no extra wiggle, no alignment issues, and it was super smooth.
mopar4don
thanks bakerhillpins.
Quote from: armor64 on May 12, 2021, 06:30:18 AM
Ok that makes me feel a little better. knowing someone else had the same problem but that it worked out.  :2thumbs:
mopar4don
I found someone to help me get the back end of this put together. The 1st thing we did was get the roof skin is on!  :yesnod:
green69rt
You can never have too many vise grips, Huh.
mopar4don
Quote from: green69rt on May 18, 2021, 12:02:11 PM
Right you are, I've been collecting them for a while and when you do a roof, you need a lot of them! :coolgleamA:
mopar4don
I stripped the e-coat off the quarters, deck filler and valance corners, and sprayed with epoxy primer. I took it all the way down to bare metal. I know, I probably could have just scuffed them up but I wanted no possible problems with paint.
mopar4don
Then I got some single stage color sprayed on the back side of the deck filler.
I will get color sprayed on the back side of everything I can.
No one else seems to do this but that's what the guy who is helping me suggests.
The quarters will go back to get sprayed color on the back side. But for now they are going back home with me for a wheel well fitment.
Once all the panels are painted then they can get welded on. At least that's the plan
keepat
Color looks great Don! Good luck with the paint!
Pat
Back N Black
Man you are doing a great job. where are you located in New Brunswick? I'm in Oromocto, would love to see your project sometime. :cheers:
mopar4don
Quote from: keepat on May 20, 2021, 06:55:36 PM
Pat
Thanks Pat
Quote from: Back N Black on May 20, 2021, 07:40:52 PM
Thank you for the compliment but I am in Michigan.
cbrestorations
While quarters are off spray color on inner structure too
mopar4don
Quote from: cbrestorations on May 21, 2021, 08:46:40 AM
Hey Cris, Yes that is the plan.
The guy that is helping me (THANKS KOLLY) says that's how he does all of his cars. And after he explained it, it all made sense!
I just always thought that epoxy primer on the back side of panels was good enough. And I don't see anyone on these forums putting
color on the back of panels. Or if they are I guess I missed it.
hemi-hampton
Quote from: mopar4don on May 21, 2021, 09:33:27 AM
You must of missed my post from 2007. I always (usually) paint the hidden areas behind Panels. LEON.
http://www.dodgecharger.com/forum/index.php/topic,35671.0.html
green69rt
Ditto. Also allows some side-to-side movement of the assembly when rolling the window up and down.  Just tried on mine and it does move  bit.
