Charger carburetor
Started by chargergil, August 20, 2013, 11:59:24 AM
chargergil
I have a 1970 Dodge Charger 500 with a 340 engine with a 4 barrel carb.  I am thinking of replacing the 4 barrel with a Carter 2 barrel carb.  What problems would this create if any?  Would I have to change the manifold? I appreciate any feedback.
Gil
yes, changes would include manifold, carb, fuel lines, kick-down linkage, and maybe gas pedal cable....
also, air cleaner
not sure why you wanna change it...keep yer foot out of the secondaries and you will get better mileage with the 4bbl
Maybe a switch to a spreadbore would help you.
myk
It'd be more money and trouble to change it than it would be to just lay off on the gas pedal from time to time.  Also, IMO removing a 4bbl and putting a 2bbl on a Charger is like taking an NFL cheerleader and cutting one of her 34DD's off...
Quote from: myk on August 20, 2013, 06:56:18 PM
No it wouldn't.  You just have to put the other 2 carbs on it as well.
If you're running an aftermarket square bore manifold, you could just put on a 2bbl adaptor.  You might have to adjust your linkages to deal with the added height and check your hood clearance.
cudaken
Quote from: chargergil on August 20, 2013, 11:59:24 AM
Gil
Like other here I am wondering why Gil?  :scratchchin: :shruggy:  :popcrn:
I am back
chargergil
To all you fellow Charger owners, thanks for the input regarding the changing of the 4 barrel carb.  I had heard different opinions about the swap, but I was pretty much thinking of keeping it.  I knew that by asking this forum I would get the correct info.
Thanks again
Gil
