grill frame to fender bolts
Started by cdr, August 07, 2013, 05:59:59 PM
cdr
when i got my car the grill was in the trunk,i have the 2 side brackets fender to grill frame,my grill is done, but i would like some pictures of the correct mounting bolts. L brackts to fender & grill frame & on top grill frame to fender & also the nuts that go on the studs,i got a bucket of bolts that came with the car. :shruggy:
thanx charlie
cdr
bull
I looked to see if I could take some pics but the bolts are so buried now I can't see them. I just used a process of elimination to figure mine out. IIRC they are 5/16" thread, bull nose bolts with a 1/2" hex head and a captive free spinning washer, which is probably about 3/4" diameter. I think they are about an inch long, minus the head of course.
cdr
green69rt
These some of them?  As you can see I've done nothing on my grill yet.  Not looking forward to the process.
bull
Quote from: cdr on August 12, 2013, 11:04:45 AM
thank you BULL  :yesnod:
You're welcome. I hope you find them.
Quote from: green69rt on August 12, 2013, 12:22:46 PM
It's not too bad. The most tedious part of it for me was taping off the headlight doors and center section for the silver face on the verticle bars. That and reattaching the broken pieces and rebuilding the broken mounting pads. It took me about three weeks to complete. http://www.dodgecharger.com/forum/index.php/topic,67850.525.html
cdr
very good,,also when you start doing your grill,call me & i will come over & show you what i did to fix mine.
