Started by Shields14, August 05, 2013, 10:09:29 PM
Shields14
i have a chance to buy a 69 440 it was originally out of 69 rt charger  any ides what it is worth  prertty good shape  said it runned when he pulled it long time ago.
 :o  any chance you have a vin number ?    :popcrn: :cheers:
Shields14
i will get one today
Shields14
alright i could not get to vin numbeer today due to the tight spot he has this thing stored he is suppose to have it out friday so i can look it over. however i could read the front stamp pad and it was  f 440  with a upside down c under that and 24 under that.  pretty sure the f means 70 and it is 440 but no idea on the 24
Shields14
heres the numbers  2536430 8    6  21   69                       vin on engine  oc106475
Cooter
While many seem to think the "HP" means something when dealing with Mopar BB engines, IMO, the "HP", or whether or not it was out of an "R/T" or not means nothing. The same exact block/crank/and sometimes rods (Save for the "six Pack" rods which are too heavy for any kind of RPM anyway IMO), could be found in a "LP" version of the 440 in grannies 4dr Imperial.
Only if your looking for a "correct" replacement would these numbers means anything, or add any type of value. Round here, 440's range from $500.00 "Runable" [NOT Locked up] or Rebuildable [Possibly locked up, but can be free'd, or needs boring/etc]..To anywhere around $1000.00 or more for one actually in the car, running and has had some engine work done.
Quote from: Shields14 on August 11, 2013, 06:41:30 PM
:cheers: thanks for the info appreciated   , when I see an ad , for a 69 charger R/T motor  , I've just got to ask what vin !  just incase its the needle in a field full of haystacks ,  ::) :o ,  my missing motor  :'(
Quote from: Cooter on August 11, 2013, 07:28:47 PM
Only if your looking for a "correct" replacement would these numbers means anything, or add any type of value. Round here, 440's range from $500.00 "Runable" [NOT Locked up] or Rebuildable [Possibly locked up, but can be free'd, or needs boring/etc]..To anywhere around $1000.00 or more for one actually in the car, running and has had some work engine done.
:yesnod:
1970 block built at the Jefferson Ave plant ("C" in the VIN stanp)...not from a Charger
Shields14
what is it out of some kind of chrysler?  newport and such
Looks like Imperials were built there
69CoronetRT
Quote from: Shields14 on August 12, 2013, 01:40:31 PM
Jefferson built Chryslers and Imperials so it could be from either.
Since your pad markings don't indicate an HP assembly....
The only optional 440 for a Newport or Newport Custom was the HP TNT so it's looks like it's not out of a Newport.
It's a LP engine so that leaves the possibility of a 300, T&C Wagon, New Yorker or LeBaron.  :Twocents:
