JB weld
Started by Bob, July 19, 2013, 06:27:26 PM
Bob
What is better than JB weld for pot metal?
DC_1
I've used JB on a cast intake for my lawnmower. It worked well and hasn't let go for probably going on 15yrs. Just grind a good "V" in the area to give it something to bite into
Nwcharger
Prep is everything. I used jb weld on a radiator top tank over ten years ago and never had a problem. Also used it when I was 11 to fix a cracked case on my yz125. It really works good as long as the prep work is done right.  :2thumbs:
1969 coronet wagon
Bob
Cool, thanks guys.
Bob
We've used it to fix Briggs and Stratton engine blocks for our go karts when the rods came out.  Stock pistons for those just don't hold up too well.
Tilar
I used to use Titanium Putty from Devcon for a lot of repairs and it holds up very well. You can drill and tap this stuff but it is very expensive for the amount you get.
Dave
Bob
Well, the tab I was trying to reattach with JB weld did not hold. I cleaned and sanded the two surfaces very well. I'll have to try tilars stuff.
Tilar
How thick is this pot metal?
Dave
Bob
Quote from: Tilar on July 20, 2013, 06:23:08 PM
I would say about 1/8 inch. It' a mounting tab on my hideaway headlight  surround that the grill/flip up door goes in.
areibel
It doesn't do great as a glue on a stressed part unless you reinforce it.  Can you drill a 1/8 hole through and pin it?  Coat the pin and the mating surfaces with the stuff then clamp it tight.  I'm not sure what the part you're fixing looks like, can you post a pic?
Bob
This morning finished what little I had to do to complete the 1972 hideaway assembly into my 74 bumper. The tab did little to strengthen the assembly so I left it off. Everything is tight.
Tilar
Dave
Bob
