What's wrong here?
Started by Dreamcar, July 11, 2013, 08:03:37 PM
Dreamcar
When I look at the k member from the front of the car, I noticed that something seemed "off". The passenger side seems to be more towards the front of the car (look at the gaps in the pictures). Could the K member just unaligned?
There's no evidence of the car having been hit at all in the front, so I'm wondering if this is just an adjustment issue or something worse. Ultimately, in a few years when the car is ready, I want to be able to have it go straight down the road.
Your thoughts are appreciated? I hope the attachments worked.
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
Dreamcar
I can`t get the pictures to attache :flame:
green69rt
Until we get pics there's nothing to advise, but the k-member does not have any adjustments, it just bolts in place!!
Dreamcar
trying again
Dreamcar
other side
Dreamcar
Your thoughts are appreciated.
spoolinhard
Is it possible that those plastic shields could have been installed by the factory in slightly different distances, making the K member to appear off? Why not measure from the front of the K member to the front of the frame rail and be sure?
those shields on my cars are not equal to the K-member either
Bryan
see replies in the other thread
Bryan
green69rt
green69rt
Please remember that the frame measurements were plus or minus 0.25.   Is it that close?
fy469rtse
Check sides of rails for any obvious damage, if you cant see any, I think you are good , checked mine for you and the are different per side, just the way they were installed from the factory, its not the rails , its the splash shields
Dreamcar
I guess the tape measure doesn't lie. I ignored the plastic shields and measured nothing but the frame rails and the k-member. Everything seems square (or very close). I guess I should worry about it.
Quote from: Dreamcar on July 12, 2013, 06:41:46 AM
I would not worry about it...the shields are a bit off, not the K-member
Bryan
Dreamcar
Thanks for all you replies. I feel better now. :icon_smile_big:
