Brake problem
Started by red72chrgr, August 06, 2005, 09:01:25 PM
red72chrgr
Hi folks. I have a 72 w/318 mostly stock. The brake pedal goes to the floor and won't come back up on it's own. I checked the wheel cylinders and none are leaking. Fluid level is good. Could this be a booster problem? Any thoughts or help will be appreciated.  :)
Nothing personal, just business
Have you bled the lines to each wheel ??
68 RT
If you have no leaks, I would say master cyl. is bad. Or as Chryco said try bleeding the brakes.
A booster problem is more likely to manifest itself as a very hard to push to the floor brake pedal or a mysterious vacuum leak.
Charger_Fan
If the pedal doesn't return, I'd say it's either dirt/rust in the cylinder bore (need new Master cylinder) or possibly the brake pedal pivot is bound up.
red72chrgr
Thanks for all the replies and possible solutions. I'll keep trying to figure it out.
