A little help. I'm back asking for trouble
Started by DadsCharger00, June 29, 2013, 10:39:52 PM
DadsCharger00
So I've finally decided to start an play with Gr8ce again.  Since my dad passed id driven her but its time to get busy again..dad wouldve wanted that. So here it goes.   Electeonic ignition.   Which one..and why.  How hard to install....can I do it. Second. Ton of heat incar. Can I make it stop.  Which hose if there is obe can I cap off to slow the heat down.  Hard to drive right now without cooking! Thanks guys.  Nice to be back.
Fred
ICE electronic ignition..........why?.............because it's the best!    :Twocents:
Log on to their website and check it out.  :2thumbs:
NHCharger
I converted both of mine to the Mopar electronic ignition. It's fairly easy to do yourself.
Are you saying the heater won't shut off? For a temp fix you could install an in-line shut off valve in one of the heater hoses in the engine compartment.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
fy469rtse
By the time you play around with heaters hoses, you could fix the cable ? Heater tap , more info to why its on or getting hot inside, have tried playing with heater controls , Fred is assuming you in Australia, distributor mod or accell, or one of the hei built in on eBay , curve on them not great, you have to take it to some one who knows to set curve, but in doing that you have also found the person to install it,
Quickest fix for the heat, remove both hoses from the water pump and put plugs in the pump housing.  Your heater valve is stuck which could be a leaky seal or a stuck cable most likely.  Is this an A/C car?
Not sure about the ignition.  I have the orange box, that's all I know.
Welcome back!   :2thumbs:
Pete in NH
Hi,
On the electronic ignition conversion, I'm sure you will get many opinions. I like the Mopar Performance Orange box conversion kits. They are simple to install and come with good installation instructions, not to mention everything in one complete kit. Also, if you need to, you can get a standard Chrysler control box in any auto parts store to get you home again. They use the stock ignition coil as well.
chargerboy69
Quote from: Dino on June 30, 2013, 08:03:49 AM
Mike, I agree with Dirk, this is the quickest way.  I did this on my black Charger, worked great. Just take a wrench and pull out the two places the hoses slide on, and put in two plugs.  They may come out kind of hard. Oh and wrap some Teflon tape on the plugs, at least I did to prevent leaks.
As far as ignition, I run a Mallory set up, works great. It good to see you back on the board.
As a side note, I did get your text last night, we were at a get together, will get back with you today.
Indiana Army National Guard 1st Battalion, 293rd Infantry. Nightfighters. Fort Wayne Indiana.
A government big enough to give you everything you need, is a government big enough to take away everything that you have.
--Gerald Ford
ACUDANUT
Quote from: Pete in NH on June 30, 2013, 09:34:09 AM
Hi,
^^^This is all I use. Anyone can do this easy conversion.
Bypass the heater core.
