Please help ID radiator
Started by flathead1946, May 28, 2013, 07:26:16 AM
flathead1946
Can anyone ID this radiator? It came with my 1968 charger. It is a 26 inch radiator and does fit in the car. However the fan shrould does not fit. I think its a C body? I could not find and part numbers on it. If is is a C body where would I get a fan shroud to fit. thanks In advance.
flathead1946
other picture
ws23rt
What is the number on the top tank?
flathead1946
I didnt see any number on it. I will look again when I get home
Mopar Nut
ODZKing
Otherwise you can try Bob and GlenRay radiator.  They would also have shrouds.
http://www.hemiradiators.com/
Glen-ray Radiators, Inc.
2105 North 6th Street
Wausau, WI 54403
PH: 800.537.3775 or 715.842.3352
Mon-Fri, 7AM-5PM CST
contact@hemiradiators.com
Just out of curiosity, is the fan shroud metal or plastic?
flathead1946
68 rads take a two piece metal shroud.  My guess is you have the right rad and the wrong shroud.
flathead1946
Anybody have a pic of the correct shroud for a 68 charger or know where one could be found?
ODZKing
Hmmm, don't think so Sean.  2 piece is only 22inch, this is 26.
2785434
Should look something like this. But this link is not 68.
http://www.ebay.com/itm/OEM-Mopar-26-Radiator-Fan-Shroud-B-body-Dodge-Plymouth-Charger-Road-Runner-GTX-/321128823400?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4ac4c4fa68&vxp=mtr
bill440rt
If there are no numbers on it, it might be an older aftermarket Modine unit or similar.
I have a one-piece plastic '69-style shroud on my '68 with a 26" rad, fits fine just doesn't look "factory correct". Rad is a re-cored 26" C-body unit.
There should be 3 mounting holes on one side, and two on the other.
Do you have a pic of your shroud?
Oh, my bad.  I had always thought the two piece applied to both.  Sorry about that.
flathead1946
I will get a picture of the shroud when I get home thanks everyone
flathead1946
Here are some pictures of the fan shroud I have, I also rechecked the radiator and did not find any number. the bolt hole on the radiator for the fan shroud are about 7 inches vertically apart and 28 inches horizantally apart. any ideas to what shroud might fit?
ODZKing
That would be a shroud for a 67 "C" body with 26 inch rad.
bill440rt
flathead1946
I called and it appears that fan shroud will fit so I bought it. I will update once I recieve it. thanks everyone
