Timing Cover Seal
Started by ChargerRob, April 15, 2013, 08:34:48 PM
ChargerRob
How do you change the timing cover seal on a 440?  Is it pressed in? Thanks in advance.  :cheers:
Mighty Mean Mexican Mopar
Fred
charger500rt71
Simply yes. I assume you are referring to the balancer/crank seal. Most guys will simply and carefull use a block of wood and a hammer to set the seal. Very easy don't over think this. Good luck.
bobs66440
FYI, If you don't have the timing cover off the engine, it presses in from the back, so you need to remove the cover to install the seal. As mentioned, just carefully tap it in.  :2thumbs:
ChargerRob
Al
Quote from: charger500rt71 on April 16, 2013, 04:46:12 AM
works fine  :yesnod:
1968 Dodge Charger, 383, UU1
