Opinions on Goodmark Quarter Skins?
Started by Monziac, April 09, 2013, 07:53:12 PM
Monziac
I know AMD is the best, but does anyone have opinions on the Goodmark skins? I am not doing a concourse resto, just a nice driver.
Thanks,
Jon
Indygenerallee
The bodylines arent so great on some of the Goodmark panels, I put a set on a Challenger and I was not happy with the bodylines but this was before AMD. plus the AMD panels are thicker metal.
charger_fan_4ever
Lines on the AMD's leave alot to be desired.
Depending on how bad your originals are I would buy a full 1/4 and cut out the sections you need for patches.
In my case I had no option my sail panel area,top skin and over the wheel even was all rotten. Figured even with small rot issues it would be quicker and a better job to change the whole 1/4. Not the case.
After all the fittment issues are overwith your left with wavy panels and bad lines, so you still need to give the (in my case) $2000 1/4's a coat of mud front to back and block it BEFORE you can even start applying high build primer and start blocking.
Indygenerallee
QuoteLines on the AMD's leave alot to be desired.
I have a set of full quarters for my 69 and yes, they are shit but compared to the Goodmark ones still alot better.
What good are decent body lines if the entire panel is shaped half an inch wrong in multiple places?
The Goodmark quarter skins are shit.  Fixing bad body lines on the AMD panels is a minor problem in comparison.
Finn
When I put 1/4s on my charger AMD didn't make them, so I used goodmark. Not only did I over pay for them being young and stupid, when I went to put them on I realized how screwed I really was. They were awful. Unless you have a shrinker/puller and a lot of time to put into making them work, Id go AMD. I bought a full fender from them and it was excellent.
2002 Dodge Ram 5.9L 360
2014 Dodge Dart 2.4L
Indygenerallee
Yes my fenders from AMD were perfect I will give them that! Quarters I was not real happy with but as I stated before much better than Goodmark.
Monziac
Thanks guys, so yes on Goodmark :icon_smile_big: Just Kidding....
Jon
Charger-Bodie
The goodmark panels are fine if you need both lower patch panels, but they are horid if installing the entire skin.
Monziac
Wow, I just got my AMD skins and what a piece of crap..... Cant wait to start bondo on this... Metal guage is nice, but wavy as hell and I could have drawn better body lines drunk with an air chisel. This should be fun!
Finn
Mind posting some pics? I'd be curious to compare them to the goodmarks.
Patronus
Weird how the quarters on the Charger from AMD needed so much work. These Ebody ones fit so well you dont even need to weld em..
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
Ryan
Quote from: Monziac on June 24, 2013, 08:47:15 AM
They typically are a little wavy but the way you describe them sounds worse then they usually are. Try calling AMD before you get to far into it. They may send you another set.
Quote from: Patronus on June 25, 2013, 10:23:03 PM
Ya it's rediculous how well the e-body cuda quarters fit compared to the charger quarters. It's really to bad that they are capable of making some seriously good stuff but the quality is just not consistent across the board.
69 charger r/t Triple Black
   572 HEMI, Passion 5 speed, 4.10 Dana under construction
2014 viper TA
Monziac
I will post pics when I get home, but very dissapointed considering how expensive they are. Goodmark quarters were straighter but not as sharp, nor as heavy guage steel, but I venture to say would have been less work. I order my parts through a local body shop to avoid shipping charges so I would have to go through them.
Thanks,
Jon
green69rt
It seems that the parts I have bought thru AMD vary some in fitup.  Some went in with almost no work, such as my quarters and wheel wells, some were a bugger (front floor), some had a poor finish (my front frame rails had a layer of dirt under the EDP!!)  Seems like their quality control is hit-or-miss.    Also I would guess that some of their parts are cloned off of parts they have borrowed from old cars rather than built from drawings and specs.  If so then the new parts depend on the old parts being straight and true.   As for having straight panels with no waves it seems that with todays technology the that should be a given!!   :Twocents:
Still, for a  lot of parts they are the only source so we have to take what they give and complain...
Ryan
Quote from: Monziac on June 26, 2013, 08:07:46 AM
Thanks,
Jon
I almost always purchase AMD from other vendors, I still deal with AMD directly when I have an issue with the product. Never had a problem with them taking care of it providing there was something they could do. My passenger side full quarter seemed wavy compared to my drivers side so I called them, they sent me a new one for free. The new one was a little better but still had its flaws.
That being said I'd rather have a thicker gauge panel on my car with a little mud on it then a thin gauge panel like the goodmark quarters.
2014 viper TA
Monziac
Thats good to know Ryan, this is my first time dealing with them, and also my first Mopar.  Generally as a company gets your money they dissapear, so anymore I dont even get my pulse raised because I know how it is gonna end.  Capturing the wavy in the panel is hard to see, but look at the body line how it goes up and down, and there is a blue X in back where the whole back is pressed inward.  Its obviously all fixable, but the reason I am replacing the quarter is because it is damaged not because I want to start hitting it with shrinking hammers and dollies and applying filler over the whole panel to get it straight.  I will call them and see what they have to say.
Thanks,
Jon
Monziac
I just called AMD and they said this is a phenomenon they have been seeing and that they think the tool is screwed up.  They said it is only on the right side, but confirmed they are having a quality issue on the panels.  He is gonna look around for a better panel for me.  I have to say, I didn't expect such a warm welcome when it came to complaining about their quality.  Then again, I wasn't a jerk about it either....   :2thumbs:  I will let you knwo how it turns out, but you may want to post a thread out in the forum so people know the quality issue they are having.  I am the new guy.... Nobody trust the new guy when he is complaining.   Ha!
Thanks,
Jon
That's impressive that they will admit to a screwy tool.  Most companies will swear it's anything other than a defect rooted in the tooling or production method, even if it means claiming the same temporary problem for 20 years (Legendary interiors).
Monziac
I agree, I was surprised at his honesty, but appreciated it. He is sending me another quarter but said he couldn't find one without flaws. I told him just to find the best one he can. At least they are trying.
Jon
Patronus
I too had a heck of a time with the right Charger quarter. Pretty bad rear of the wheel opening to the marker hole.
'08 CRF 450r
'12.5 450SX FE
Monziac
New panel showed up, and its as bad as the first. I see on their website, the panels are now "out of stock".  It did have a "made in taiwan" sticker on it, so I was dissapointed in that.....
Jon
Indygenerallee
Mine looked the same way, The fitment is great just alot of waves, it's gonna take hours upon hours of repeated blocking to get these things mirror straight  :rotz:
Monziac
I would almost prefer to buy a rotten quarter, repair it and put it on...... This is pathetic. Cant believe they are selling this, and at a premium..
QuoteI would almost prefer to buy a rotten quarter, repair it and put it on...... This is pathetic. Cant believe they are selling this, and at a premium..
I'll send you a rotten used quarter panel in exchange for your wavy AMD one.  Deal?
The same panel made in the USA would cost a couple thousand dollars each.  Classic Body Designs produced it a few years ago.  The public voted with their wallets.  People didn't like spending $4-5k just for a set of good quarters.
