Wilwood SS Hoses
Started by Mopar2Ya, February 19, 2006, 03:16:27 PM
Mopar2Ya
I have Wilwoods on all 4's. The car was all power drum & has a Dana. What do I need for stainlessteel hoses? Length, size, etc.? I've tried to order the hoses but I keep being told that I need to figure out what I need, & that the rear needs to use 3 hoses one on each Wilwood to hard line then the one to the body. Can hard line be run to the 2 rear Wilwoods? Can I use 15" wheels w/the Wilwoods?   :smilie_help:
1970 Charger R/T
2006 GC SRT8
phat69charger
You can go on the advance auto site and look up the factory parts and they might tell you the length you need, I think the factory front lines are 18" long, you can go on the wilwood site and look up the pieces you have and the PDF page will probably say the parts you need, I think you are wasting time asking members here what to use, when no one knows exactly what wilwood brakes you have, you can lookup your brakes because your the only one that knows which ones you have, then go on the wilwood site in the plumbing section  http://www.wilwood.com/Products/008-Components/002-SBF/index.asp
You have to figure out what you need as far as the length, you can measure the old lines if you still have them, if your body is still stock and you haven't modified it the factory length's should work, and should do a search for wilwood brakes on this board and who ever you find that has them PM them and ask them what they used.
I have run hard line all the way into the rear wilwood calipers you just need a pipe to inverted falre fitting to mate them up
