71-74 Inner fender rods to firewall
Started by Charger454, October 24, 2012, 08:05:15 PM
Charger454
Will the two "Fender To Firewall" brace rods from a 73 Charger fit a 71 Road Runner? See attached pic.
Thanks!
I have no "sense of entitlement". I only deserve what I've got off my ass to earn!
71charger_fan
The '71 doesn't have the firewall stud to which they mount on the later cars. If you add that, I don't imagine it would be a problem.
Paul G
My 72 had the firewall stud. Still the rods had to be modified to fit.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
Charger454
Modification? Elaborate please. Also, from these two replies, I'm guessing that Mopar added them in late 71? Why? For crash strengthening? Thanks
Paul G
Quote from: Charger454 on October 25, 2012, 05:21:45 AM
The rods were too long to install as they were. I had to elongate the slots on the fire wall side, and trim the end of the rod at the fender side to get them to bolt up. Easy enough to do. They stopped the front end of the doghouse from moving around while driving down the road. They added a little stability to the front of the fenders, bumper, grill area.
Paul G
Also, on the passenger side The rod touched the hood hinge when the hood is closed. I had to make a slight bend in the rod to clear the hinge.
plum500
I made one out of some 1" square and a few pieces of angle iron. Seems to really reduce flex.
Here's a thread...
http://www.dodgecharger.com/forum/index.php/topic,46777.0.html
chargd72
Good thread.  I have a '72 as well and a set of '73 braces.  They are a bit longer but like Paul said, if you elongate the holes in the braces you should be able to get them to fit.
Keeping the discussion alive, is there really a benefit to using them?  I mean is there a noticeable difference?  I never put them in because I'm not crazy about the look.
Thats where fenders differs on bolt location between 71/72 and 73/74 ( along with the rest of mounting diff even perfect match with body lines )
Charger454
Quote from: chargd72 on October 25, 2012, 10:08:55 AM
I couldn't have asked & said that better!
So essentially, with minor modification, these will fit all the 71-74 Mopar B-Bodies?
ACUDANUT
