battery in trunk
Started by Highbanked Hauler, July 17, 2012, 10:10:28 PM
Highbanked Hauler
 When you put a battery in the trunk you obviously run the positive cable to the starter. What about the negative cable,can it be anchored to the body or does it have grounded to the motor ??
92 Cummins Turbo Diesel
04 PT Cruiser
macca3441
You can connect your negative to a body earth (just make sure its a nice, clean, tight connection), then use another battery cable to earth between the body and engine block!
Make sure all connections are clean and tight, and that you've used good quality battery cables!
I prefer to use 0B&S, or 00B&S cable.
Wade
FLG
Quote from: macca3441 on July 17, 2012, 10:20:11 PM
Wade
Yep. Thats how its done with factory trunk mounted batteries.
I have often run the negative cable back to the rear of the trans to make sure it grounds properly
Highbanked Hauler
Quote from: Chryco Psycho on July 18, 2012, 07:11:52 AM
  I was wondering because of the little cable that grounds the motor to the firewall  :2thumbs:
04 PT Cruiser
I have only moved it to the trunk on two cars but in both of those cases I grounded the battery to the trunk floor and the engine to the firewall as normal. :Twocents:
Paul G
My only concern is these unibody cars are welded together. Not intended for the body to carry high current. Newer cars with battery in the trunk are designed for it. I would do like Neal said and run the neg cable to the engine block or trans. If it was me.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
FLG
Quote from: Paul G on July 18, 2012, 10:15:00 PM
Not true, a lot of newer cars are unibody..if not mostly all.
My 87 BMW has a little piece in the trunk welded to the quarter panel and battery is grounded on there, but is VERY important to make sure your engine ground is good.
macca3441
Quote from: Highbanked Hauler on July 18, 2012, 08:41:25 AM
Please re-read my first response!!
Wade
that little cable from motor to firewall is not large enough to carry starter current
Bryan
FLG
Quote from: A383Wing on July 18, 2012, 10:46:31 PM
Bryan
Agreed (not to mention its 40 years old), hence as macca said..you need to run a higher diameter cable from engine to the body.
A larger cable for a ground is a good thing to do.  I run a larger and a couple of extra ones on my car as it is.  I also wouldn't be concerned about the current in a unibody.  It will be just fine.
