440 swap
Started by coxie1996, April 23, 2012, 09:12:54 PM
coxie1996
so im doing my 440 swap and was told i need a 971 pan (center sump) for it.. (using schumaker mounts) i have the truck pan, either front or rear sump not exactly sure right now.. will this work for the swap from a 318 to 440 in my 73 charger
Cooter
Rear sump is "Truck" pan..I would think any center sump, Car pan would work. Some "Hemi" pans were larger capacity, but will still work.
Rear sump pan won't work in a car with stock K frame.
ACUDANUT
What's the engine out of
coxie1996
engines out of a 73 RV. and thats what i thought.. hmm ill have to find one
I would just order a new Pan & pickup from Mancini for $160 or so
coxie1996
Im on a budget $160 for a pan wont work. If the ones i ljsted above will work ill be fine
the top one is the best bet , the middle one is lower capacity & the bottom one is a C body pan . You will still need the pick up tube though
coxie1996
will the top pan fit though?
ACUDANUT
I believe I have a oil pan and pick up tube for you.  How does 75. sound
ACUDANUT
What are you doing for exhaust manifolds.   I have a pair of factory (non HP) and a new set of headers for 150.00
coxie1996
Quote from: ACUDANUT on April 24, 2012, 10:39:34 PM
im running headers and need those along with a pan.. i could do 50 on the pan if thatll work. im 15 and on a TIGHTTT budget but please let me know  :2thumbs:
what brand are the headers?
ACUDANUT
Okay, it's yours. PM me your e-mail and I will send pic's.  Not sure on the brand of headers.  I think they are headman's.
coxie1996
on my 400BB i found it had a "933" oil pan.. will this work?? i would post pics but it wont load..
ACUDANUT
Well do you or don't you want my Oil pan and pick up tube.
coxie1996
i do unless this one will work.. need to save all the money i can
ACUDANUT
I hear ya, Let me know
coxie1996
Will do, still need those headers and mounts.. Read my PM
coxie1996
sorry but never got an answer... will my 933 oil pan from my 400 fit on my 440 going into my 73 charger swap? looks to be center sump
Inspector71
Coxie1996: You are 15 and doing this work? I salute you. I wish I had gotten into this when I was your age. I am
               waaaaaaaaaaaaaaay older and can tell you that if you keep going the way you are, you'll be teaching people like me about cars real soon. If I had the stuff you need, I'd give it to you just to see your project done.
