head light switch
Started by cowboy4x4n, January 22, 2012, 08:37:41 PM
cowboy4x4n
guys, need alittle help.
69 charger head light switch is acting up.  feels warm to the touch.  not sure if thats normal.  i cleaned the back of the metal connectors and used dialetric greese.  while driving and turning lights on the dash  panel lights wont come on unless i move the switch slightly down.  also while driving the lights will turn off ever so often making it really fun in the dark wooded roads.  any suggestions.
cowboy4x4n
any  help guys.  any ideas what the issue is.  i think with the brights on a while the switch acts up more
bill440rt
I'm no electrical whiz but it sounds like your switch is taking a dump. Especially since you have cleaned it already & are finding that jiggling it causes your dash lights to come on. Check your connectors at the dash harness as well. Make sure none of the wires are loose where they are inserted in the connector.
Replacements are out there, reproduction switches are currently available.
nvrbdn
heat is resistance. bad connections, dirty connections. if the contacts are cleaned and power can flow,i would agree that the switch itself is bad. :yesnod:
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
cowboy4x4n
well cant expect everything to last forever.  42 years had a good run lol.  thanks for the input
bakerhillpins
As far as the dash light dimmer/switch is concerned my 69 does the same thing. I have to wiggle the dial just a bit to get them to come on. I only get ON, any other "dimmed" setting is just off. I need to take the dash out and clean and test or by a new one.  Was a bit interesting driving home until I realized that I just needed to fiddle with it to get my dash lights back.
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
bill440rt
Quote from: bakerhillpins on January 23, 2012, 09:37:54 PM
The design of these original dimmer switches just suck.  :smilielol:
The coils are very fragile, & are prone to breakage and/or wear. Mopar Action had a great tech article a while back with a fix for these things, you might be able to find it archived on their website. I don't think the repros are that expensive, and might save you some time dicking around with your original switch as a "maybe" to get it to work.
twodko
Same issue with my '69. I bought a new headlight switch (OUCH!) and got it installed without pulling the dash (you'll need to pull the drivers seat for this task). The old one had some connector melt on it but the dimmer portion was unaffected thankfully. My HLs still came on and off for no apparent reason. I checked all other connections and grounds then Nacho suggested the dimmer switch may also have been damaged. Sure enough a new dimmer switch and now all is well.
cowboy4x4n
Oh wow maybe ill try that first.
Hey Cowboy,
  There is an internal breaker INSIDE that switch for the headlights. (The wipers switch has one too.) If the contacts are old and corroded that could be the problem. Remove the switch (Granted no small job!) and carefully take it apart for cleaning and reassembly. while your at it remove the dimmer and clean it's contacts also, you may be OK then!  :2thumbs:
  Your lights are going out from to much resistance, clean headlight bulb connectors contacts and clean the ground for them also try replacing the High/Low foot dimmer switch, as they are cheap.
