Let me see your custom gauge clusters (2nd Gens.)
Started by jaak, December 31, 2011, 12:59:00 PM
jaak
I am thinking about re-doing my gauges, My factory ones suck and are inaccurate.
Been toying with the idea of getting another gauge housing that I can hack on and installing new Autometer (maybe) Speedo, Tack, Oil pressure, Fuel, Temp and Volt gauges.
Another question, if I decide to do this... there have been several topics about repro fuel senders being incorrect due to the sender being constructed like a chevy sender (0 ohms empty/60 ohms full) compared to Mopars (10 ohms empty/73 full). Should I get a fuel gauge for a chevy sender instead of a gauge calibrated for a Mopar sender. Just thought that would 'correct' the Fuel reading, since I have a repro sender.
Thanks,
Jason
Rolling_Thunder
I think if you use a GM gauge and sending unit piece you would be fine - you would need to verify the ohms on the replacement sending unit to be sure it will work correctly though
68RRFlyer
Just restored this entire dash for a customer.  68 Dash, New Vintage gauges.  A LOT of fabrication, but worth it in the end I think.  Small ones are recessed behind the bezel, circa stock,  with a bolt in housing so I can remove all the gauges if necessary.   Tach and speedo mounted from the front.  Also removable.   :2thumbs:
Cheers :cheers:
Dave
1969-1/2 A12 Super Bee
1970 Challenger T/A
1964 Corvette Convertible
1949 Chevy 3100
Charger-Bodie
Quote from: 68RRFlyer on January 22, 2012, 09:07:50 PM
Cheers :cheers:
That is by far the coolest non-stock cluster Ive ever seen. Great job.
The70RT
jaak
Cheers :cheers:
Very nice! Looks awesome.
Jason
