Rear 10" brake upgrade
Started by metallicareload99, July 21, 2011, 10:36:57 PM
metallicareload99
Hello, how do I identify what size rear drums I have?  318, 4 wheel manual drum car, 8 3/4" rear.  I believe I have the 10" diameter, 1.75" width.
I am also wondering if there is a larger size (wider?) I can upgrade to without having to change out backing plates?  I think I have found some 10" X 2.5" drums for the rear and matching shoes, can I just put those on and go?  Thanks in advance
all my Chargers are 10" x 2.5" drums from the factory...sounds like you got somethign else different...
bobs66440
I think you will have to change the backing plates. Yours should be flat(ish) and I believe the wider ones are inset toward the center of the rear. Another member here is in the process of upgrading also. He should know for sure.
metallicareload99
I looked at my rear drums and they are definitely more narrow than the front drums, which are 10" by 2.5."  They (rears) are most likely the 10" X 1.75," is this a factory set up?  It all looks pretty stock, thanks again
you don't say what year and kind of car...so telling you if it's factory brakes or not is kinda hard
metallicareload99
Quote from: A383Wing on July 22, 2011, 11:05:54 PM
1968 Dodge Charger
