Front sway bar
Started by MORFF, March 27, 2011, 04:31:59 AM
MORFF
My 69 Charger had a  front sway bar stock. Will the Hotchkis front sway bar mount to the same points that the factory stock front sway bar mounted to tks? If so I have the stock mounts and the front sway bar for  the front for a 69 Charger if anybody needs one.
Mike O
A.K.A Dirty O
Semper Fi
dangina
they are bolt in oem installations from what i have read
bill440rt
You will need to drill additional holes in the K-frame for their mount brackets. And, supposedly they won't fit if your K has a factory skid plate.
They'll fit a standard K no problem.
MORFF
Mike O
A.K.A Dirty O
Semper Fi
Musicman
According to the Hotchkis on line installation instructions, you weld their bracket to the K-frame.
