Dipstick tube help!!
Started by FLG, March 13, 2011, 03:48:50 PM
FLG
Hey Guys,
Having issues with my dipstick tube, its a milodon tube
http://www.summitracing.com/parts/MIL-22070/?rtype=10
It slides right into my block without any resistance so i know im going to have sealing issues.
Any ideas on how i can remedy this?
Its basically the last item before i bring it to the dyno on wenesday  :brickwall:
:scratchchin:
4aThrill
is there an o-ring on the tube?
bull
You might try coating the base with Hylomar before installing it but it really should be a tight fit. Something is wrong with that tube IMO.
FLG
Nope.
:RantExplode:
Is there supposed to be a bottom o ring? There's no machined area on the bottom for one to slip into. I h don't have the packaging anymore but I remember it being the correct part # also it seems to be the correct length.
Does anyone have a measurement for the hole diameter?
I think so bull. I might order a sock replacement and another milodon from summit tomorrow for next day.
Or does ma mopar sell a replacement at the dealer?
Seems like every rigid tube I've got in recent years was too big, had to sand them down to fit.
I would guess that the end is intentionally made small so it installs easy, it'd be pretty hard to drive that in and get it out otherwise; I'd just smear a generous amount of RTV on the end and depend on the top bracket to hold it in place.
bull
Quote from: FLG on March 13, 2011, 04:31:27 PM
There are still stock replacement tubes and sticks available through the dealer. That's what I bought (tube only).
http://www.dodgecharger.com/forum/index.php/topic,75096.0.html
FLG
Thanks guys.
Might order a cheapie one for the dyno run.
Can't seem to find an o-ring that would work without a groove in the tube for it. Maybe some permatex and teflon tape for the time being.
another suggestion.... take a round tapered punch and tap it into the lower end of the tube and make it a little bigger...
large amount of silicone will not seal forever....any movement on the tube will work that loose and you will have a leak
resq302
Frank, what I did with mine when I got a new dip stick tube was to put a little bit of RTV on the tube.  So far no leaks and I really wouldn't worry about it vibrating and causing leaks since it attaches to the one bolt for the motor mount.
Brian
FLG
Thanks Guys!
I decided to wing it.
I took out a marker traced a line around it and took out my dremel and used a cut off disk to make a groove in the bottom, slipped an o ring into the groove and some permatex and it went in with a bit of force, seems to be nice and tight  :rofl:
kamkuda
I just put that same dipstick on my car yesterday.  The instructions suggested a bit of RTV to seal it.
resq302
Quote from: FLG on March 13, 2011, 10:44:42 PM
Frank, you ARE talking about the part for your engine on your car,right?   :smilielol: :nana: :rofl:
Brian
I'm sure the rtv would have been fine but the o-ring is a good idea  :2thumbs:
FWIW ; every Mopar dipstick i've installed had to be ground down but the 440 Source dipstick that I installed in the 446 fit like a glove with no mods. Go figure  :icon_smile_big:
Yeahmate
O your so lucky.... it fitted that easy  ;)
This is what I didn't to make my Milodon dip stick, fit and clear.
Buy a' fit all' dip stick to find it fits FA cut it up, grab some 5/16'' tube and fittings and make your own, also a little grind on the block to up accommodate the fitting  :rotz:
[/img]http://i52.tinypic.com/idym54.jpg[/img]
4aThrill
my oil tube has a bracket on it that attaches to the engine mount so it would stay in the hole and I also put a o-ring on there too just in case nice and snug.
