gears....
Started by chargerguy22, January 20, 2011, 10:09:51 PM
chargerguy22
wne to turn on car this morning and put seatbelt on, fixed my tunes, opened garage wanted to put the car in reverse but gear wouldnt switch. its stuck on park.... any ideas on whats wrong n how to fix it??
FLG
What year charger are we talking about here?
chargerguy22
its a 2006 3.5 high output
FLG
When you mean stuck in park, does the handle move out of park or is it physically stuck there?
There is a shift lock bypass mechanism (not sure where on those new chargers, (this sites mainly for 66-74 chargers but there are a few on here that own both) usually its near the handle somewhere on the console and requires you to remove a small cover and simply depress the button under the cover, this will disable to shift lock as its possible something is broken. Is your garage on a slope? Sometimes if you put it in park and the weight of the car is now resting on the park sprag, that could cause issues when trying to shift back out of park.
chargerguy22
it moves maybe 1/2 an inch to the right but thats it. it doesnt slide down to the other gears. my car turns on everything seems fine it just doesnt want to shift out of park.
my car is inside the garage but i do have a slope on the driveway
FLG
If the garage is level or fairly level than what i wrote isnt an issue.
Check this out
http://dodgeforum.com/forum/dodge-charger/214618-2006-dodge-charger-wont-shift-out-of-park.html
doctor4766
One of my mates was telling me just today that his Avenger had the same problem and that it is a recall problem.
Gotta love a '69
tatrick2me
 ;) http://www.youtube.com/watch?v=P_QMSBpYThI Here is a video that will show you whats wrong and how to fix it.
Bone 7
did you step on the brake before moving the shifter?
Could be simple as no brake lights meaning a bad brake light switch
