440 lean burn?
Started by Rayzor, January 07, 2011, 06:01:58 PM
Rayzor
I pulled out my part boxes digging for another distributor. I have 3 factory electronics to pick from. Is it possible one is from a lean burn setup? if so whats the difference. I have a orange ignition modul already hooked up.
chargerbr549
The lean burn distributor won't have any weights in it and no vacuum advance, if I remember correctly.
Kevin
Rayzor
oldkimmer
............also ur timing is locked at whatever timing u set it at..........kim.....
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
Cooter
Most Lean burn distributors have TWO PICK UPS, along with two sets of wires...One to start on and one to run on...
