69 bracket placement??
Started by lexxman, December 17, 2010, 04:39:17 PM
lexxman
Hey all.I got my spare tire and jack brackets,but I don't know where they go.I was wondering if anyone had some pictures of the trunk?
green69rt
See if these help.
lexxman
Ya,thats perfect. I didnt know about the up on the wheel well.What the spacing between the two jack brackets on the floor? These are the last things to be welded in and then that part of the rebuild is over. :2thumbs:
green69rt
You can almost eyeball them.  If you have your jack just let it be your guide and put all the places where they fit.  MOPAR wasn't exact and so you don't have to be either.
lexxman
I don't have a jack,its on the to get down the road list. I don't really what to pay $300 or so for a jack.
Thanks for the help
green69rt
Hang on And I'll go make some measurements.
green69rt
OK, lay a tape measure flat on the trunk floor with the end against the inside of the tail light panel.  Distance to the first bracket is 4 1/2 inch.  Distance to the little wire loop is 18 1/2 inch.  These are on my car.
lexxman
Thanks this will be good I'm off between Christmas and new years,so I plan to finish that up then.And then its on to sanding.
