Motor mount bolt set
Started by bull, October 26, 2010, 01:13:53 PM
bull
Does anyone sell bolt kits for all the motor mount fasteners? Or, does anyone have a list of sizes and lengths so I can do it myself? Are they typically all grade 8 bolts?
Thanks. :cheers:
Charger-Bodie
bull
Quote from: 1HotDaytona on October 26, 2010, 01:46:39 PM
www.megapartsusa.com
Do you have a link to the actual part because I checked with them before posting and didn't see anything.
Charger-Bodie
bull
Quote from: 1HotDaytona on October 26, 2010, 04:17:28 PM
Quote from: bull on October 26, 2010, 04:14:42 PM
http://www.megapartsusa.com/products.asp?cat=5&pg=3
Thanks. I just found it while you were posting this apparently.
bull
You know, I just can't seem to conjure up a good reason to pay $20 for two bolts.
terrible one
Quote from: bull on October 29, 2010, 01:48:26 AM
You shouldn't! Got all mine from the local fastener store. The ones that bolt the mount to the k frame and the ones that mount it to the block. I will get you the lengths, etc. tonight
Charger-Bodie
It all depends on how picky you are about things looking right. Myself ,I could stand a hardware store bolt ,but to each his own.
terrible one
Very true. If you do choose to go the hardware store route I went out and measured for you.
To start, I'm pretty sure all are 7/16" diameter but I couldn't get a good angle to measure so you should check the hole sizes.
They are all 5/8" hex head. The bolts on the ears of the block are fine thread, and the two that bolt through the k frame are coarse thread.
The two k frame bolts are 4.5" long.
On the drivers side, the top two are 2" long and 1.5" long. The lower one is 5" long.
On the passenger side, the top two are 2" long and 1.5" long, and the lower one is 2" long.
+flat washers for the ones on the block ears. The k-frame ones thread into the motor mount.
greenpigs
I go to Lows all the time, looking for some stainless plugs for the firewall curently. Not sure of what there name is but the back is serated & you spread that out to hold the plug.
1969 Charger RT
Living Chevy free
