Oil pump ID?
Started by terrible one, September 18, 2010, 07:46:54 PM
terrible one
I'm not sure whether it was on this board or not, but I recently read a few threads that mentioned with the stock lower capacity oil pan it was a bad idea to run a high volume oil pump due to the possibility of it sucking the pan dry.
I bought my longblock secondhand and in short was wondering how I could tell if the guy had put a high volume or high pressure pump on it vs. stock just by looking at it?  :shruggy:
RD
fwiw, i ran a HV oil pump with a stock oil pan in my ramcharger and 72 charger for years with no issues.  the only time i believe you will have an issue with the HV oil pump and a stock pan is if you are hitting 4500 rpm or higher on a regular basis.   :Twocents:
terrible one
Worth enough to give me a bit of piece of mind. I guess I'll quit stalling and start this thing up for the first time already  ;)
RD
 :cheers:
